2wd Cossie Boost Problem
Old Jan 12, 2007 | 10:13 AM
Daveesaunders's Avatar
Daveesaunders
Default 2wd Cossie Boost Problem
I've just fitted a -31 Actuator as I thought there was a problem with the standard one as it used to peak at around 12psi and hold 10psi, a few months back it dropped to peaking at 6 and holding 4.
Now it peaks at 6 and I lose power the engines standard bar a K+N filter and Mongoose exhaust and the actuator I've just fitted.
Im just going to fit new fuel filter but Im not sure if this is the problem.
Can anyone shed some light on this. I am going to get it set up in the month or so but I need to get it running a bit better than it currentyl is before I arrange it.
Old Jan 12, 2007 | 12:31 PM
Daveesaunders
Have now fitted the new fuel filter and lengthed the rod on the actuator a bit. Still peaks at 6psi and 3000rpm and cuts out
Old Jan 13, 2007 | 08:44 AM
Daveesaunders
Old Jan 13, 2007 | 09:02 AM
nellyscossy's Avatar
nellyscossy
that sound strange..standard should peak 12 and hold 9....are you running everything standard..dump valve ,chip,etc.. also when you say cutting out do you mean misfire or total cut out(as though ign was switched off)
Old Jan 13, 2007 | 09:03 AM
abdr500's Avatar
abdr500
you have to shorten the rod to make more boost do it so you have to pulll the rod over
Old Jan 13, 2007 | 09:16 AM
Alan s1's Avatar
Alan s1
You forgot the Half a Hole
Does that mae sence As Abdr500 sayes pull it over half a hole is around standard bost i was told
Still not sure why it would cut out tnh as a cossie will run with a boost hose off unlike the RST
Old Jan 13, 2007 | 09:21 AM
Alan s1's Avatar
Alan s1
Or if its boosting but just runs out of puff it could be a boost hose poped off this happened to me
Old Jan 13, 2007 | 10:33 AM
Daveesaunders
Dump valves a Forge Motorsport Item on the cold side, chip is standard.
I original set the actuator up using the half hole method and it was a nightmare to drive, got to 6psi really quickly and the car nosedives violently, engine keeps running but theres no go, about a second later it gets going again but once it hits 6 psi it does it again.
I've lengthend the rod and its made it a bit better to drive but still does it.
I'll have a look at the boost pipes and see if ones come off.
I may have a go a shortening the rod tomorrow.
Old Jan 13, 2007 | 12:14 PM
nellyscossy
sounds like overboost!!!but shouldnt be anywhere near that at 6psi...now im confused
Old Jan 13, 2007 | 12:27 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
could be a faulty map sensor?
Old Jan 14, 2007 | 09:11 AM
Daveesaunders
Checked the boost pipes all appear OK, think I'm going to get a new MAP sensor and chip and get it to a RR. More expense
Old Jan 14, 2007 | 05:08 PM
Alan s1's Avatar
Alan s1
Old Jan 14, 2007 | 08:48 PM
Daveesaunders
I think there may be a problem with the amal valve, can any one provide a diagram of where the three pipes should connect. I wnat to make sure I've got it connected right. I have just got a second hand one of eBay so I'm hoping this could be the problem.
Oct 9, 2015 07:38 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
RsS2daz
Aug 14, 2015 05:26 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
lockie
Jul 31, 2015 10:03 PM
