cosworth turbo damper question bolting the turbo solid
Old Jan 11, 2007 | 06:06 PM
abdr500's Avatar
abdr500
Default cosworth turbo damper question bolting the turbo solid
can a turbo damper on a cosworth be bolted up solid to the turbo and the to the rocker cover like the bailey one but with out the rose joint bit and just have a simple adjusting rod. as I cant see whey you would want any part of the damper to flex. more info or would be nice as looking at a pic of Karl cosworth he has a turbo damper that looks to be bolted up solid but not sure thanks
Old Jan 11, 2007 | 06:20 PM
biglee's Avatar
biglee
Audio specialist
yes you can but you will need a spacer like a pice of ally tube or a load of washers(which looks gash) or some good washers and a smaller bolt.... just be carefull not to bend the bracket on the turbo when you do it up...
Old Jan 11, 2007 | 06:31 PM
abdr500's Avatar
abdr500
biglee
i hear what your saying but i am going to make one from scratch with stainless steel solid bar and tube a bit like the bailey one but one to suit my manifold and turbo
Old Jan 11, 2007 | 06:53 PM
abdr500's Avatar
abdr500
any one else
Old Jan 11, 2007 | 09:52 PM
abdr500's Avatar
abdr500
any one have photo of ther coustom made turbo dampers
Old Jan 11, 2007 | 11:03 PM
col cos1's Avatar
col cos1
il show u ine the morn no pics the now
Old Jan 12, 2007 | 05:27 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
iam not sure on this,but doesnt the hanger have to move to allow for expansion of the manifold when its glowing red hot?
Old Jan 12, 2007 | 08:14 AM
abdr500's Avatar
abdr500
col cos1
Old Jan 12, 2007 | 08:19 AM
abdr500's Avatar
abdr500
if I use a rose joint would it not just pivot.what exactly is the damper suppose to do take wait off or stop the turbo rocking as the bailey one looks like it will just pivot
Old Jan 12, 2007 | 10:51 AM
cozmeister's Avatar
cozmeister
More boost Igor!
The damper's there to take up the torque the turbo creates as it spins - ie, it's there to stop the turbo twisting itself off the head.
Old Jan 12, 2007 | 03:05 PM
abdr500's Avatar
abdr500
cozmeister
yes i know but the rose joint that the bailey damper has it will just pivot as the bearing will allow the twist movement or am i not right
Old Jan 12, 2007 | 03:16 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Have asked Bailey - will post their reply
Old Jan 12, 2007 | 03:26 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
the standard damper is a harmonic resonation damper
Old Jan 12, 2007 | 03:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as above. the std damper has a specific job to do.
others that you have seen are more turbo supports, rather than dampers to take some of the weight of big turbo's off the manifold
Old Jan 12, 2007 | 03:50 PM
abdr500's Avatar
abdr500
ok so the ones bailey sell are more turbo suport but i still cant see how it will carry any weight if its got a rose joint on it as it will pivot and pull away may be its just me need to have better look at it
Old Jan 12, 2007 | 03:55 PM
Turbosystems
Super Moderator
The standard manifold is amply strong enough to support the turbo's weight under all operating conditions.
Old Jan 12, 2007 | 03:58 PM
abdr500's Avatar
abdr500
Turbosystems
yes your right but i dont have a std item and turbo sit a different position
Old Jan 12, 2007 | 04:01 PM
Turbosystems
Super Moderator
design one to suit your application
Old Jan 12, 2007 | 04:17 PM
abdr500's Avatar
abdr500
Turbosystems
ok this is what i have done so far i have made a nice turbo damper /support but not sure on the end i should use ie a rose joint or weather to bolt it up solid to the turbo what do you think
Old Jan 12, 2007 | 04:26 PM
Ryan's Avatar
Ryan
the one im going to do will be mouted to the manifold flange rather than the turbo and will have 2 small rose joints to allow for adjustment.
Old Jan 12, 2007 | 04:35 PM
abdr500's Avatar
abdr500
why the manifold i gess its to stop it cracking but once the turbo is supported shouldnt that be all that is needed
Old Jan 12, 2007 | 04:39 PM
Ryan's Avatar
Ryan
this tubular manifold hasnt cracked before, and its lasted 9yrs.
so im just going to copy the design for mine, cant use the one that was originally used as it was design for a 2wd head and i dont have the lugs on the head to mount it the same.
Old Jan 12, 2007 | 04:48 PM
abdr500's Avatar
abdr500
I C
Old Jan 13, 2007 | 01:22 PM
abdr500's Avatar
abdr500
any one else on this topic
Old Jan 13, 2007 | 03:11 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You are trying to support a Turbo not hold it solid. Lots of temp differentials & vibrations going on, must have 'give' somewhere or something will snap/crack.
Old Jan 15, 2007 | 12:09 PM
cozmeister's Avatar
cozmeister
More boost Igor!
If it's any help, here's the answer I got from Bailey - I asked how it works differently to a standard turbo damper:
It is designed to offer superior support for the turbo, as the standard Ford dampers wear quickly and service parts are now quite difficult to get. It mounts on three of the standard cam cover bolt fittings and comes with a pair of spherical adjustable joints to get the tension correct (instructions included). As it uses the came cover fixing bolts, these means that it will fit both 2wd and 4wd heads/cam covers, but not the later type Escort Cosworth silver cam cover.
Hope this helps
Old Jan 15, 2007 | 01:43 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
That is what it is SUPPOSED to do, so that it will allow for the growth of a tubular manifold, whilst still providing the support required. If it has no freedom of movement (it will be mm's), then it WILL crack. So it MUST be rose jointed.
I would personally modify a Bailey one to suit your application.
Old Jan 15, 2007 | 01:50 PM
abdr500's Avatar
abdr500
Mike Rainbird thanks thats what i wanted to no
now sorted i have made a nice damper /support with rose joints
Old Jan 15, 2007 | 02:15 PM
Ryan's Avatar
Ryan
cant upload the photo of mine
Old Jan 15, 2007 | 03:19 PM
Lloyd's Avatar
Lloyd
told ya
jaimesdna
Aug 25, 2015 06:59 AM
A.t.p
Aug 15, 2015 11:37 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
