****Computer peeps - Internet issues!****
Old Jan 11, 2007 | 09:27 AM
dvid's Avatar
dvid
Default ****Computer peeps - Internet issues!****
Morning all,
I have set up a Netgear wireless router, which is connected via cable to a PC, and a laptop connects wirelessly. Now the internet works fine on both of them, BUT.......
On the PC (XP) there are more than one user (5 in fact), the internet only works with the user that I set the thing up on, the other users' internet won't work as it seems to try and use the old broadband conenction, even though the network indicator thingy down the bottom shows as being connected to the router.
Any thoughts as to how I can set it up so that all teh users on the PC can have access, or is it something on teh router that I need to do?
Thanks in advnace
Dave
Old Jan 11, 2007 | 10:04 AM
dvid's Avatar
dvid
Old Jan 11, 2007 | 10:09 AM
m4cK's Avatar
m4cK
Sounds like an authority issue, you will need to give full permissions to other users or it could be that the other users are still looking at the wrong path to connecting to the internet, in which case try running through the internet setup wizard bit. hope this helps.
Old Jan 11, 2007 | 10:17 AM
dvid's Avatar
dvid
m4cK Thanks for that, I am hoping that it is authority issues, but where would I find these settings?
The connection settings for all users seem to be the old Tiscali settings, but the PC just picks the internet up from the router without any signing on / connecting, just click on internet explorer and away we go
Old Jan 11, 2007 | 10:25 AM
Thrush's Avatar
Thrush
Irritating c........
YOu need to log in to the PC Admin account (master account) and allow the settings to be used for all users on the PC
Old Jan 11, 2007 | 10:28 AM
dvid's Avatar
dvid
Thrush
Cool, I set it up using the admin account, where will I find these settings? I am being such a goon as I work in IT But its easier in a law firm its all set out for you
Also this place is on a farm with horses and cats, both of which I am highly allergic too lol, its like extreme IT
m4cK's Avatar
m4cK
I recon you will get away with uninstalling your old internet software/settings and running internet connection wizard or another way is to go in manually through Internet explorer-tools-Internet settings-connections-setup, once you in the wizard you want to click on - "connect to the internet" - "setup my connection manually" - Connect using a broadband connection that is always on" - finish. give that a bash
Old Jan 11, 2007 | 10:29 AM
m4cK's Avatar
m4cK
Im guessing you dont want to go through making everyone else administrators on the computer so i would suggest trying that first.
Old Jan 11, 2007 | 10:36 AM
dvid's Avatar
dvid
Perfect I reckon you might of cracked it there..... cheers
Mark_
14
Jan 16, 2016 05:27 PM
cossie362
Oct 11, 2015 03:53 PM
SMILER258
Sep 28, 2015 09:04 AM
paceo
Sep 25, 2015 08:05 PM
