cosworth dash illumination
Old Jan 11, 2007 | 07:08 AM
K1COS's Avatar
K1COS
Default cosworth dash illumination
my lights on my escos's dash went out for 90 % yesterday, also the lights in the turbo/ baatery/ oil pressure meter went down....
serious problem or easy to solve???
let me know thx
Old Jan 11, 2007 | 11:12 PM
SafeChav's Avatar
SafeChav
Not really touched on Escos's (bit too pricey for me ) but could just be poor connections on the connector to the instruments.
Either that or the dreaded fuse box failure all MK5 and above escorts suffer from
Old Jan 13, 2007 | 10:28 AM
DENNIS's Avatar
DENNIS
check the lamp display dimmer switch ( lower left side of the dash )
you may have just knocked it when cleaning it , or it could be faulty...
as you have only 10% of light its the most likely cause....
Old Jan 13, 2007 | 03:43 PM
MarkN's Avatar
MarkN
It could be the invertor that's inside the instrument cluster breaking down. When these start to go it affects all the dials including the 3 centre ones...
Old Jan 13, 2007 | 04:49 PM
SafeChav's Avatar
SafeChav
They have an inverter in thew instruments?
Old Jan 13, 2007 | 05:21 PM
Andy E's Avatar
Andy E
It could well be the inverter or it could be the electroluminescent faces.or both.Could be the dimmer which is easy to check out with a multimeter as its only a variable resistor.check out the escort cosworth forum as this topic comes up time and again.and again
Old Jan 18, 2007 | 05:38 PM
MarkN's Avatar
MarkN
Oh yeah - Escos instruments don't use bulbs as such - the dial faces are electroluminescent and glow green when an A/C voltage is put across them at the right frequency.
The inverters that convert 12v DC to AC to bang and you lose the lot.
Old Jan 18, 2007 | 05:42 PM
SafeChav's Avatar
SafeChav
As soon as someone mentioned the elctroluminescent faces above i worked it out, i didn't know they had them, thought it was just conventional bulbs
Old Jan 18, 2007 | 05:54 PM
MarkN's Avatar
MarkN
Would be a lot simpler if it was bulbs... Does look good tho when its all lit up
Old Jan 18, 2007 | 11:13 PM
RSandy's Avatar
RSandy
the lights in my mk5 escort van dash somtimes decide to go tits up, and a swift punch to the top of the dash usually does the trick
thats what i like, cheap easy fixes
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
andyrs1600i
Aug 30, 2015 07:21 PM
