sump.....
Originally Posted by MICKY84
you have to drop the cross member, un -plug crank sensor and dont forget to undo turbo oil return pipe or you'll split it!!
Originally Posted by SWIFTY
its gotta come off so i can take my pistons out
i havent got the room in my garage to be able to take the rest out i already have the head of so i can put the bk in the top.
does anybody know if i can just drop the crossmember or has it gotta come off??
Originally Posted by rs nuts
just drop it down the crossmember
it will just give you enough room
thanks mate so if i undo the 4 bolts i will be able to drop it enough to remove the sump???
shall i support the crossmember with a jack as the steerin rack is atached to it???
thanks
yes undu the 4 bolts ,unclip the brake pipes which are attached too the cross member
and also undu the steering colum were it joins too the sterring rack then it will give you enough room
no need too support the crossmember i dident
how many bolts hold the steering colum to it??
is it hard to remove??
-J-
29
Apr 7, 2005 06:31 PM
