dry sump. no need for breathers ????
right we have got a dry sump kit to go on our zetec turbo
but am i right in saying we can block the breathers off as technically they are no longer needed as any crankcase pressure will be tacken out via the the oil resovior tank in to a catch tank, if you know what i mean.
yeah i was wondering if you could actually notice the differance or weather it was one of those small things you need a lot of to feel the benifits.
ill let u know how it goes but itll be in the late part of this year till she is on the track
I think the pump spec will state whether or not you can run in vac. It needs to have a big enough scavenge stage to support it, only place there will be a breather will be at the top of the oil tank then
My slim jim pump(iirc 3 stage) can and thats pretty much one of the most popular pumps used.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
timsrs
22
Sep 24, 2015 08:14 PM
