Series 1 Coolant Sensor
Old Jan 10, 2007 | 08:33 PM
MichaelG's Avatar
MichaelG
Default Series 1 Coolant Sensor
Changed 3 of the little buggers on the same car now, and the low water warning light is STILL ON on the dash
Anyone got any ideas ??
Old Jan 11, 2007 | 11:09 PM
SafeChav's Avatar
SafeChav
Whats the light doing?
Flashing for 30 secs after turning the ignition on or just constantly illuminated?
Old Jan 11, 2007 | 11:11 PM
MichaelG's Avatar
MichaelG
Constantly on matey !
Old Jan 11, 2007 | 11:14 PM
SafeChav's Avatar
SafeChav
Was hoping you weren't going to say that.
If you've put 3 different switches in it can only be the ECU. Were they all new?
If there was fault on the circuit it would flash.
The ECU's are a bit shit to be honest
Old Jan 11, 2007 | 11:20 PM
MichaelG's Avatar
MichaelG
No all second hand mate, could it not be a broken wire ?
Old Jan 11, 2007 | 11:22 PM
SafeChav's Avatar
SafeChav
you wish
If theres a fault on the circuit the bulb flashes when you initially switch on to tell you the circuit has a fault.
The switch changes between 2 resistances, if the ECU doesn't see either resistance it knows there is a fault.
Have you got a multi meter? And without being rude, presumably you have topped the level up yes?
Old Jan 13, 2007 | 12:25 AM
MichaelG's Avatar
MichaelG
Yes mate got a multimeter and yes i have topped up the level lol
What you thinking next ?
Old Jan 13, 2007 | 01:28 PM
SafeChav's Avatar
SafeChav
Put the meter across the switch, and move the float up and down, you should see the resistance change from about 1500 ohms (float down) to 300 ohms (float up).
If the switch tests out ok you'll probably need to change the ECU.
Old Jan 13, 2007 | 05:54 PM
MichaelG's Avatar
MichaelG
The ECU as in the whole car ecu ? Or the yellow box ecu ?
Wheres the Yellow aux warning ecu located ? I actually have a spare one of these.
Old Jan 13, 2007 | 06:16 PM
SafeChav's Avatar
SafeChav
The yellow box
But they can also be blue, black, green etc lol
Take the centre grille out of the dash, its below that. 2 x 10mm nuts, and they usually need prying off and they stick to the sound deadening on the bulk head.
Old Jan 13, 2007 | 06:39 PM
MichaelG's Avatar
MichaelG
Likely to just be fooked or can i test it ?
Old Jan 14, 2007 | 02:03 PM
SafeChav's Avatar
SafeChav
Just change it mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
