running in???
Old Jan 7, 2007 | 04:13 PM
ianshad6's Avatar
ianshad6
Default running in???
just out of intrest how many mile do you lot run in your new engines????this is for an rst???any ideas???????????????
Old Jan 7, 2007 | 04:25 PM
Stoo's Avatar
Stoo
They say 1000 miles but i'd say 700, change the filter and oil, get it set up and away you go!
Old Jan 8, 2007 | 09:29 AM
ianshad6's Avatar
ianshad6
i thought so as i was told 200mls but iwas also told 700-1000 then oil filter & oil then set iknew he was wrong!!thanks mate i should have listen to the tunner as he was right and my mate was wrong and he works for ford?
cheaRS
Old Jan 8, 2007 | 03:43 PM
SafeChav's Avatar
SafeChav
You want some cheap oil to run it in on aswell.
Old Jan 8, 2007 | 04:02 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default Re: running in???
depending on what has actaully been done
full engine rebuild-remember to run cam in for 20 mins at 2k rpm
id do about 800-1000 miles on shitty oil,stayin off boost and low rpm for around 500 of that,then introduce small boost and a little more rpm
then oil/filter change and set up/rr
shells/rings etc-i reckon around 500 non abusive miles adding small bosst and revs as the miles clock up
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
