Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Oil Temps and Surge problems
Old Jan 4, 2007 | 10:21 AM
AX Cossie's Avatar
AX Cossie
Default Oil Temps and Surge problems
I assume these can be overcome by big wing sumps.
What about oil coolers and baffles? any use or just an expensive accessory?
Do any of you track boys have any problems with oil surge?
Old May 10, 2007 | 08:50 PM
Fiecos Dan's Avatar
Fiecos Dan
In my Fiecos,
i run a big wing sump (6 ltrs), and gates and baffles.
Even with 28oC ambients, and 30mins hard track session, it never goes over 105oC oil temp, and no oil surge issues.
In my xr2tt,
i run my own baffle's sump, and a 16row Mocal oil cooler.
before i done the sump (i've tried a couple different design's), i have oil surge on most corners, and it has even put 2 cams out, Since i havent had a issue.
Before i fitted the oil cooler, i was seeing 120oC oil temps in 10 min's hard session, i now see no more than 110oC after 20+ session.
Old May 24, 2007 | 03:41 PM
Daxcossie's Avatar
Daxcossie
Can you describe what oil surge is ?
Old May 24, 2007 | 06:22 PM
Fiecos Dan's Avatar
Fiecos Dan
There's 2 sorts of oil surge.
1st sort is when oil rushes to the sides of the sump on cornering, and in turn the oil pump dont have enough oil to pump round the engine, and the oil pressure drops.
2nd sort, is when the oil splashes around the sump on corners, and fills the breather system up, and can empty.
Old May 27, 2007 | 09:14 PM
Daxcossie's Avatar
Daxcossie
Thanks for that.
So, by having a windage tray installed aswell as a big wing sump inc baffle and a high pressure 4x4 oil pump it should not get any surge problems.
Old May 28, 2007 | 08:48 AM
Fiecos Dan's Avatar
Fiecos Dan
thats right.
Old May 28, 2007 | 08:54 AM
Fiecos Dan's Avatar
Fiecos Dan
Originally Posted by Fiecos Dan
thats right.
and by far the best rates and service i could find. lol
Old May 28, 2007 | 08:56 AM
Fiecos Dan's Avatar
Fiecos Dan
fuking thing.
foget the last post. i was meant to reply on another thread. doh.
Old May 30, 2007 | 07:26 PM
steven botes's Avatar
steven botes
i simply extended my sump about 50mm with 1mm plate and now put 5l of oil into my motor
i use a mazda rotary oil cooler which is about 50cm long by 5cm thick by 15cm wide
never see temps above 100'c , even with ambients in summer around 30'c
the more oil in your sump , the less chance of oil pulling away from the pickup
15
Oct 7, 2015 03:43 PM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
