What size oil cooler? and sump questions
Old Jan 4, 2007 | 09:40 AM
AX Cossie's Avatar
AX Cossie
Default What size oil cooler? and sump questions
What size oil cooler will be suffiecient for a 420bhp turbo engine?
Does anyone reun remote oil filter and thermostat for the cooler?
Whats the capacity of the existing sump and is there a real need for a big wing sump? Is the standard item not up to scratch?
sorry for the q's but im new to the ford scene and wanna know as much about my engine as possible so i can make some informed decisions.
Cheers!
Old Jan 4, 2007 | 09:43 AM
dave cos4x4's Avatar
dave cos4x4
i have a big wing sump on mine,no oil cooler.
seems to do the job.
Old Jan 4, 2007 | 09:49 AM
AX Cossie's Avatar
AX Cossie
sweet, how much did that set you back?
Old Jan 4, 2007 | 10:21 AM
dave cos4x4
bought the sump all done,a used one.
think Martin @ Reyland does them,round about Ł350.
Old Jan 4, 2007 | 10:30 AM
AX Cossie's Avatar
AX Cossie
nice one
ive also posted a question in the technical section if its too technical for GD.
Old Jan 4, 2007 | 10:31 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u can send ur sump to Mike rainbird of here and he will get it done for u a lot cheaper.....
Old Jan 4, 2007 | 11:22 AM
NUTS RuS's Avatar
NUTS RuS
I'd say somewhere around a 19 row will be fine
Old Jan 4, 2007 | 05:26 PM
DENNIS's Avatar
DENNIS
i am fitting a 19 row cooler with stat and remote filter at the mo, remote filter not really needed but will look trick !!!
well up to the job....
Old Jan 4, 2007 | 07:17 PM
AX Cossie's Avatar
AX Cossie
sweet, Ill probably get the same, im getting mine from think auto unless i can get em cheaper froma trader on here?
so the YB is pretty good for oil surge probs then? No baffles required?
Old Jan 5, 2007 | 09:11 AM
pete mcrash
ur sump is baffled...not like major baffled and gated but it has it's own....what u going for....sump or cooler????...the reason i got a sump was that even if u loose/use a bit oil u've still got plenty......
Old Jan 5, 2007 | 09:15 AM
AX Cossie's Avatar
AX Cossie
ill probably go for both
Ill start with the cooler as they arnt too expensive and then maybe get my sump modified. The dude building my car should be able to make a big wing sump for not a lot of money.
Old Jan 5, 2007 | 01:21 PM
Turby2's Avatar
Turby2
First off I'd fit an oil temp sensor and monitor the temps. If it goes much above 125C then you need to fit a cooler. Also any increase in revs over standard max or sustained high revs (on track) will probably require a cooler.
If you do fit a cooler make sure its got a thermostat - no point cooling oil when you are starting off...
Old Jan 5, 2007 | 02:49 PM
AX Cossie's Avatar
AX Cossie
Aye i thought that was true for NA engines but doesnt matter too much on turbo'd engines cos the temp of the turbo will warm things up very quickly?
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
Adam-M
Aug 26, 2015 05:53 PM
