How to stop my box going bang
Old Jan 3, 2007 | 09:29 PM
Tonks's Avatar
Tonks
Default How to stop my box going bang
What have people done to there box's on either escos's or saph 4x4's
Spec when the car is back together will be NMS low lag head, standard bottom end, t38 and 403's hopefully around 400bhp
I spoke to a few places today and was horried that its gonna cost around 5.5 k to have a decent spec box and front diff.
So what have pepole done to theres. Whats the priority and are there any cheaper alternatives.
Thanks Jamie
Old Jan 3, 2007 | 09:33 PM
NEIL A's Avatar
NEIL A
The new mullet box that reyland is selling looks to be a good bit of kit for the money, around 3K built i think.
Im running a straightcut box that i got second hand but standard diffs just now(hope to have around 400 bhp), im going to fit a diff plate and see how long it will last.
Old Jan 3, 2007 | 09:57 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Best value for money option is a Mullet box Have the standard diffs rebuilt and don't launch it too much
Old Jan 3, 2007 | 10:03 PM
dave cos4x4's Avatar
dave cos4x4
have just broken my 3rd box in 6 months...all used oxes though.
got 2 of them rebuilt to a slightly better spec,not sure what though.
i had to decide wether to spend £2-£3k on a decent box or bits on the escort mk.2 project.
the escort mk.2 won.
Old Jan 3, 2007 | 10:37 PM
charlie luciano's Avatar
charlie luciano
Default mt75
From what i've heard there aint really a cheap option when it comes to a decent 4x4 box, apart from a shot pean and i don't think that will do you any good when you are pushing 400 horsies through the car,
i'm desperate to sort out a decent box but just don't have 3 k spare to spend on the car at the moment,
my car has chewed 2 boxes from ford and i'm not an animal when driving the cossie
Luciano
Old Jan 3, 2007 | 10:39 PM
dave cos4x4
How to stop my box going bang..
don't drive it.
Old Jan 3, 2007 | 10:41 PM
NEIL A's Avatar
NEIL A
i went through through 4 boxes in 2 years including snapping the input shaft on a standard rebuilt box, also did 4th on a standard box and 3rd on an osborne bigtooth wich is in the shed and i realy need to get round to getting rebuilt
Best to spend 2/3k once if you can and save on the hassel and time off the road.
Old Jan 3, 2007 | 10:43 PM
dave cos4x4
NEIL A
i'm sure Marco can sort the box out for you.
Old Jan 3, 2007 | 10:52 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Marco Polo is the man - Mullet box is the box!
I have one in my car, together with a rear diff he rebuilt and upgraded, and a standard rebuilt front diff he did, and ALL are running fine at my 370 - 400bhp mark.
Si
Old Jan 3, 2007 | 10:55 PM
Paul_RS's Avatar
Paul_RS
What exactly is the mullet box? Had a quick look on both Reyland's and Rainbum's site and can't see them mentioned?
Old Jan 3, 2007 | 10:57 PM
dave cos4x4
more or less the same as a fix-it kit.
the mullet box comes all built up and not a box of cogs.
Marco is the man to ask.
Old Jan 3, 2007 | 11:04 PM
Si B's Avatar
Si B
Mullet box - Straight cut 1,2,3, and 5th.
4th is direct drive (cheers Porkie for reminding me last time!)
Also has big teeth. Very few original metal parts - most bigger / stronger / harder metal.
Pics of the teeth in my box:
Standard box:
Sounds nice - a little like a rally car, but not excessively loud.
PM Marco Polo for a price and proper spec, he'll sort you out.
Si
Old Jan 3, 2007 | 11:06 PM
dave cos4x4
i really need one of these.
Old Jan 3, 2007 | 11:12 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the cheepest option is to turn the boost down to 6psi
Old Jan 3, 2007 | 11:15 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As above, you are looking at quaiffe or fixit, or the new mullet boxes.
Mullet looks like the best value, quaiffe is the easiest to get bits for though probably as well catered for already.
Diff wise, if you keep the standard ones, you will need to take it steady in first, once you are into the higher gears the diffs are under less strain due to the torque reduction of the higher gears compared to first.
Old Jan 3, 2007 | 11:22 PM
dave cos4x4
mine would still break.
Old Jan 3, 2007 | 11:35 PM
Kevin Sharp's Avatar
Kevin Sharp
cheapest option is run standard power...no problems then
hope that helps
Old Jan 4, 2007 | 12:30 AM
glancy2081's Avatar
glancy2081
marco said to me that the weakest part of the box is in first gear cant remember why other than this he does not expect any problems from the mullet
Old Jan 4, 2007 | 01:46 AM
NUTS RuS's Avatar
NUTS RuS
Chip when did you last get any gearbox bits from Quaife lol their service and supply for bits lately is truly shocking
If you cant put your hand in your wallet Tonks your reduced to driving it like my grandma would unfortunatly
Then I'll give a standard box 1 week in the dry and maybe 2-3 weeks if it stays wet.
Fix that and the diff will be next so dont think it stops there.
Fix the diff and it then mullers up the centre donuts or driveshafts usually.
There is a pattern it follows and unfortunatly I have seen it all to often following motorsport like I do.
Old Jan 4, 2007 | 06:46 AM
dojj's Avatar
dojj
Resident Wrestling Legend
so there is nothing short of spending £3k on a mullet box then?
and does the normal 4th gear mean that it will retain the normal input shaft?
i'm looking for upgrades to the V6 version of the mt75 and other than the front casing and the input shaft length the rest is the same, but i don't want to spend ANOTHER shed load of money on it
Old Jan 4, 2007 | 08:14 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
The 'mullet' term is the name which Marco uses for these gearboxes, the gearbox which I sell is the same item from the same source.
Under transmission... http://reyland.co.uk/Parts.asp?ID=4
Old Jan 4, 2007 | 09:07 AM
Porkie's Avatar
Porkie
I have the Mullet box in the Sierra at the moment. Done 2 full trackdays and a 4-5 full bore launches at Santa pod and its still in one piece
Seems pretty bombproof to me
Old Jan 4, 2007 | 09:12 AM
Chip's Avatar
Chip
Link straight to the actual box itself:
http://reyland.co.uk/Details.asp?ProductID=132
And piccy of the gearkit compared to a standard one:
Old Jan 4, 2007 | 09:41 AM
dave cos4x4
Tony,
the standard boxes are not that bad,i managed to do Croft and Donnington this year with slicks on and still managed to drive home afterwards.
ok, they broke before the trackdays and used standard boxes re-fitted but they stood up to it.
i did Donnington on the 29th and 3rd gear broke again.
that was the first time its gone when driving a bit hard,normally it goes when driving it on a sunday.
Old Jan 4, 2007 | 09:46 AM
Chip's Avatar
Chip
Only on a ford forum could you find someone who changes their gearbox as often as you and finds it acceptable
Old Jan 4, 2007 | 10:19 AM
dave cos4x4
i have to accept it as i don't want to pay for a decent box.
other project to spend it on.
Old Jan 4, 2007 | 10:21 AM
Porkie's Avatar
Porkie
Didn't you mate with the Astra change boxes all the time as well??
Old Jan 4, 2007 | 10:38 AM
timrud's Avatar
timrud
Yes, I know a few big power FWD vauxhall boys that have run a 5 speed for a bit and changed them more than once a week
Then again with two of you its under an hour
Old Jan 4, 2007 | 10:42 AM
Chip's Avatar
Chip
We did 5 boxes in 400 miles in the astra
Hence at the first opportunity we got we upgraded to a much stronger box (with 6 gears too ) so we didnt have to keep changing it anymore!
Old Jan 4, 2007 | 10:43 AM
Chip's Avatar
Chip
Rob's record for utterly destroying a seemingly perfectly good working order secondhand F20 box stands at less than 2 minutes use
Old Jan 4, 2007 | 12:19 PM
kjc300's Avatar
kjc300
How noisy is it Lee??
Wanted to have a listen at donno but Renton only turned up as me and Sean were leaving!!
Old Jan 15, 2007 | 09:08 PM
marco polo's Avatar
marco polo
Standard box:
Si
Hi Simon
2nd /3rd/4th/5th are big tooth gears , 1st /reverse are standard
4th is still big tooth but it's direct thats why its quite
optional extras are for box with big tooth gears
uprated 1st gear (made as big tooth strenth/quality-standard in patern)
uprated center VC 50Nm-180Nm
uprated mainshaft ( brand new )
uprated step off chain for 3.9/4.1/4.2/4.4/5.1 ect
5% lower ratio big tooth 5th 0.76 if needed
marco
marco
Old Jan 15, 2007 | 09:26 PM
marco polo's Avatar
marco polo
Hi Lee
it's alot better than your quafie that you had that was taken out every time you used it
it's good kit the gears are well strong , I tryed to get them as cheap as i possibly could for the club / rs sceen... that do track days ect ect
i rather the box do the talking than myself
marco
massivewangers
30
Oct 1, 2015 07:40 PM
DHMC
Ford Fiesta
Sep 30, 2015 07:15 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Fudgey
Sep 17, 2015 01:06 PM
Rizlablue
Sep 6, 2015 09:58 AM
