fabrication tool???need help asap
Old Jan 3, 2007 | 08:41 PM
ianshad6's Avatar
ianshad6
Default fabrication tool???need help asap
right guys someone must know where to get one?
we are needing a tool that make a 52 mm hole in sheet metal?
as seen on the rally cars/
i spok to many peaple thay know what im on about but dont know what its called?
ithink it has a die with differnt size base holes for rolling them in nice and neet with no shape edge?
icant really explain it very well im only hoping somone know what imeen??????????
any help pls
CCCCCHHHHEEEEAAARRRSSS
Old Jan 3, 2007 | 09:05 PM
Craigb's Avatar
Craigb
52mm hole saw or a 2 inch hole saw.
What we use for pressing holes in control cabinets is a hydraulic cutter. a small hole (10mm - 13mm) hole is drilled first then the dutter is put through and with the aid of a hydraulic foot pedal the whole is pressed out.
Old Jan 4, 2007 | 07:49 AM
ian sibbert's Avatar
ian sibbert
http://www.frost.co.uk/item_Detail.a...ole%20Punch%20[1/2,%205/8,%203/4,%201
They are punches....you can get punch and dies sets that roll the edges as well....
Old Jan 4, 2007 | 09:37 AM
ianshad6's Avatar
ianshad6
like this as this is what i want to do???
Old Jan 4, 2007 | 10:18 AM
CosRush's Avatar
CosRush
http://www.nfauto.co.uk/punch_set.htm
goes upto 51mm...............
Old Jan 4, 2007 | 03:46 PM
Aaroncast's Avatar
Aaroncast
OR IF ITS JUST A HOLE ! DO YOU KNOW ANY ELETRICIANS OR PLUMBERS THEY USE THEM BUT A TAD TO EXPENSIVE AS A ONE -OFF PURCHASE!!-JUST CUTS A STRAIGHT HOLE IN TRUNKING /METAL-USED ONE ON MY TALBOT SUNBEAM RALLY CAR TO GET SOME AIR THROUGH THE BUMPER-
Old Jan 4, 2007 | 05:06 PM
ianshad6's Avatar
ianshad6
no there gona be around 40 holes?
isee the point of the hole bit but what about making a lip on the inside as it would shape as hell for ie cables or pipes fuel lines or what ever yes i have gromets but it not like iv seen before?
has anyone got any pictures of the holes thay have done as it appers that most peaple on here have herd about this tools a apose my mate or peaple where ilive just havnt herd about it at all????
appriciate the help everyone its starting to make sense where to get one from?
Aaroncast
it will be used more then once more like 20+ times at least?
thanks for all help?????????????????????????????????????????????
Old Jan 4, 2007 | 05:21 PM
CosRush's Avatar
CosRush
http://www.toolbank.com/category.cfm...FSXuXgod8zXyLg
You cant go wrong here either.............
Ł17 for a 52mm one
Old Jan 4, 2007 | 11:32 PM
NUTS RuS's Avatar
NUTS RuS
http://img144.imageshack.us/my.php?i...tbrace27nj.jpg
My mates Corsa (he has some funy ideas).
They are shaped holes as you say not just punched.
Its a two piece tool we use but it wont do 52mm
Old Jan 5, 2007 | 11:06 AM
ian sibbert
Back at home today...I have a full set of swagers, these are what you need, you drill or punch the hole first then swage the hole with the appropriate sized swager, my set goes from 1/2" to 2.5" step by step pics below....2" hole....
Hole cut with a normal hole saw..
Swaged
Another shot of the tool..
I cant remember where these came from, it says 'MB' on the tools themselves...
HTH
Ian
Old Jan 5, 2007 | 04:04 PM
ianshad6's Avatar
ianshad6
ian thats spot on just what imean so it is called a swagger is there any number or make on it so i can get one????thanks very much
Old Jan 5, 2007 | 04:17 PM
CosRush's Avatar
CosRush
I wonder if its these people???
http://www.mbtools.org/tool_man.htm
Old Jan 5, 2007 | 04:22 PM
ianshad6's Avatar
ianshad6
may be ill give them aring to moz and let you know the out come????thanks for that!!!!!!!!!!!
Flatlinedan
Sep 18, 2015 12:41 PM
Brian
Sep 11, 2015 08:06 AM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
