What causes understeer???
Old Jan 3, 2007 | 04:28 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default What causes understeer???
My mini in this shit weather seems to understeer alot
Its got Yoko AO32 Tyres - Semi slicks,neg camber arms, poly bushed front end, Spax 14 way Adjustable shocks ( set to 6 on the front, so not to hard )...
Which will cause this to happen, As I need to get it sorted, Even at 20/30mph on roundabouts it understeers and its a right cunt
Old Jan 3, 2007 | 04:32 PM
Puss2's Avatar
Puss2
Formerly know as Puss
think you have answered your own question there rad "shit weather" and "semi slicks"
Old Jan 3, 2007 | 04:36 PM
Charlie Chalk
Unknown.
I just wanted to make sure its not the neg camber...
Old Jan 3, 2007 | 04:43 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Understeer caused by a number of reasons including knackered front tyres, suspension too hard on the front, road conditions, excessive speed into the corner.
Old Jan 3, 2007 | 04:48 PM
Charlie Chalk
Unknown.
Tyres are new 2 weeks back, Suspension isnt hard..
In the wet I dont speed on roundabouts, In the dry its a different story
Old Jan 3, 2007 | 04:57 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Never driven a mini so got no idea how they handle. Is it an older one with really skinny tyres?
Remember skids are caused by one or more of the following:
A - Accelerating too hard.
B - Braking too hard.
C - Cornering too hard.
If the road conditions are bad just make sure you corner gently and don't accelerate too hard.
Old Jan 3, 2007 | 06:09 PM
Terry Tibbs's Avatar
Terry Tibbs
One, the main reason, power and steering through 2 wheels = them to spin, when they spin they lose traction, thus causing the car to go in a straight line rather than turn.
Negative camber will only work in the dry when you're taking a mediumish corner pretty hard and well as it makes the whole tyre sit on the road, in the wet, round a roundabout, i'd be suprised if it wasn't aiding the understeer.
Fact that its a mini with tiny wheels also won't help.
Although in the wet, round roundabouts, I seem to get far more oversteer.
Old Jan 3, 2007 | 06:18 PM
AlexF's Avatar
AlexF
LOL!
Its the weather matey... your driving a VERY old car remember - don't listen to the bollox that old minis are the best handling car ever as it simply is true!
On a serious note - you've got modified suspension, have you had the car setup by someone that understands minis... ie not your local kwikfit!!??
Alex
Jim Galbally's Avatar
Jim Galbally
semi slicks
seriously, you may aswell cover your tyres in oil
Old Jan 3, 2007 | 06:26 PM
S1sam's Avatar
S1sam
A032 tyres aren't actually that bad in the wet
What tyre pressures are you running?
Old Jan 3, 2007 | 06:34 PM
GARETH T's Avatar
GARETH T
weight balance aswell
saph in dorset
22
Aug 3, 2009 01:14 PM
Stavros
98
Apr 9, 2008 11:41 PM
bobfish
Sep 28, 2007 09:37 AM
wildheart
Sep 14, 2005 08:42 AM
rapidcossie
Nov 16, 2004 03:49 PM
