Idle control valve
Old Jan 2, 2007 | 09:19 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Idle control valve
Can anyone please tell me if this is a serviceable part and how is it removed as my Cosworth now idles at anything from a 1000rpm to 4000rpm. If I disconnect the idle control valve, it then seems to run fine.
Many thanks in advance.
Old Jan 2, 2007 | 09:20 PM
rapidcossie's Avatar
rapidcossie
have you jet washed the car recently?
Old Jan 2, 2007 | 10:29 PM
rabmc's Avatar
rabmc
There not bloody cheap ither i found
Old Jan 3, 2007 | 10:31 AM
KSA-Cossie's Avatar
KSA-Cossie
Take it off and clean it with carb cleaner m8.
Old Jan 3, 2007 | 11:39 AM
C0S_TURBO's Avatar
C0S_TURBO
Have not jet washed or steam cleaned the engine. Have cleaned the connectors with wd40. It seems to work as and when it wants to. Can I remove the unit and soak it in oil? Thanks for any help offered.
Old Jan 3, 2007 | 11:43 AM
KSA-Cossie's Avatar
KSA-Cossie
Old Jan 3, 2007 | 01:22 PM
Harris.'s Avatar
Harris.
2 srews either side, and soak it with carb cleaner
Old Jan 3, 2007 | 02:08 PM
Nash's Avatar
Nash
Cake lover!
My valve gets clogged with crap every few months, i took it out this morning cleaned it up and now its fine.
Woodford cant even get this part now as i asked last month. I luckily have a spare just incase my on finally dies.
Old Jan 4, 2007 | 10:33 AM
C0S_TURBO's Avatar
C0S_TURBO
Hi thanks for the advice. I have undone the two screws both side and removed or ring, but I am unable to pull the idle control valve out! How much force can I use before I damage it?
Many thanks!
Old Jan 4, 2007 | 01:14 PM
Harris.'s Avatar
Harris.
Default Re: Idle control valve
Many thanks!
I had to turn mine from side to side to get it out, keep twisting it will free up
Old Jan 4, 2007 | 01:15 PM
Harris.'s Avatar
Harris.
Burtonpower sell new idle valves £90
Old Jan 4, 2007 | 03:53 PM
MARCOSWORTH's Avatar
MARCOSWORTH
PJ also £99.95
Old Jan 4, 2007 | 04:26 PM
Nash's Avatar
Nash
Cake lover!
Cos Turbo if you cant get it by giving it a firm pull then just tap the metal bit with a hammer should come out then.
Cheers for info lads
Old Jan 5, 2007 | 10:03 AM
C0S_TURBO's Avatar
C0S_TURBO
Will have another go this evening! Many thanks for the good advice!
Old Jan 5, 2007 | 01:34 PM
Alan s1's Avatar
Alan s1
Many thanks!
Mine also does this Tried gettin mine out aswell but wont move but my T/Body is off the inlet @ the moment so will try whots been said when its back togher
Old Jan 5, 2007 | 01:37 PM
Nash's Avatar
Nash
Cake lover!
Had to clean mine up again this morning worked for 10miles then shit again Looks like the spare is coming out if only it wasn't a 200mile drive to go get it lol.
Old Jan 5, 2007 | 01:41 PM
Alan s1's Avatar
Alan s1
You only need it when you want to start the car as soon as its warm just discornect it
You can not sure it all toghter but then your have to sit there with you foot on the t/peddel untill it idles
Old Jan 15, 2007 | 04:31 PM
C0S_TURBO's Avatar
C0S_TURBO
Default ICV
Managed to free it up. Tapped it with a hammer. Full of crap!!! Cleaned it up and fingers cross it has been behaving itself. Many thanks for the great advise!!!!
Old Jan 15, 2007 | 04:51 PM
Harris.'s Avatar
Harris.
Old Jan 15, 2007 | 09:48 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I just leave mine disconnected, it idles fine as well even from cold after 30 seconds.
Steve.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
