Help needed ASAP please!
Old Jan 2, 2007 | 03:33 PM
Coxy_UK's Avatar
Coxy_UK
Default Help needed ASAP please!
Ok I am gonna have to hang around and wait for a response as I can go no further!
I need to remove the windscreen cowl panel off of my 1990 Saff. All that appears to be holding it on now are what look like three plastic screws, one each end and one in middle, along edge near winscreen. However they are clearly not screws but some strange mechanism and I don't know how to remove/undo them! Anyone know?
Incidently I am removing it to further my investigation into where water is getting in and soaking the passenger footwell. Has anyone else had this or is it a known fault that occurs after time? Any ideas?
Oh and also some electrics have stopped, i.e. clock, wipers, rear windscreen heater, fuses are not blown though.
Old Jan 2, 2007 | 05:00 PM
need4speed00001's Avatar
need4speed00001
these clips are a twat,they look like plastic srews but they only turn through a quarter turn then pull up.I broke three because they were seized in the plastic.turn them and lever up with another screw driver.
Have you checked the drains in the bulkhead panel they block up with leaves and stop the water draining off it then enters the heater onto the cabin floor.
Old Jan 3, 2007 | 11:01 AM
CosKev3's Avatar
CosKev3
As above,these do block up easily
Also,are you sure it's not coolant????????
Heater matrix leaking will fill the floor pan up
Old Jan 3, 2007 | 11:54 PM
costina's Avatar
costina
Live long and prosper!!
Engine loom grommet 85% its were people fit amps and extra gauges and don't check it afterwards
behind the glove box about 60mm in dia
Old Jan 4, 2007 | 07:33 AM
dojj's Avatar
dojj
Resident Wrestling Legend
but if you can't get to it from that end, the outside of it sits behind the abs valve block, not the easiest thing in the world to get back in again that grommet isn't
any luck with the windscren scuttle plastic screw clip removal then?
Old Jan 5, 2007 | 01:18 AM
Coxy_UK's Avatar
Coxy_UK
Cheers guys, I will check your suggestions on Sunday and get back to you.
Old Jan 5, 2007 | 07:48 AM
need4speed00001
Sorry mate those plastic scuttle clips ,do screw out not just a quarter turn like i told you earlier.I found some old clips yeaterday and could see the thread,they are a get though!!!!!
Old Jan 5, 2007 | 06:30 PM
Daveesaunders's Avatar
Daveesaunders
TheThe plastic clips are a complete bastard to get out I've broken several of these, they do unsrew all the way but they tend to seize up and then the heads snap when you undo them
Old Jan 5, 2007 | 09:10 PM
dojj's Avatar
dojj
before you undo them, go under the front wheel arch and try getting one of the inner arch liner screws out they are also tought little buggers to extract, in the same way
Old Jan 5, 2007 | 09:52 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
spray the screws with some oil before you try to remove them and be prepared to visit the scrappy for some new ones! if the heads do break off, just bash the rest of the screw all the way through the other side
Old Jan 6, 2007 | 09:14 AM
Daveesaunders
I ended up cutting these screws off
Old Jan 6, 2007 | 01:03 PM
dojj's Avatar
dojj
they are right bastitches they never stop spinning
i fuond that drilling the screw with a tiny drill bit (1mm) and sending in a normal metal screw gives it enough bit to be able to remove them
but then again, i wasn't other with spending hours doing this
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
