My car has lost the plot... (Need your help ASAP)
Was told by a neighbour my car alarm was going off so went out looked it over all was fine so went back in. Five minutes later i heard it going off again so went out and nobody there. Once again five minutes later the same thing again. But then my window wipers started to judder up and down even without a key in the ingnition. Then all the lights started to flash while at the same time the alarm was going off and the window wipers going up and down all jerky. So i turned the engine on and all was fine. Sat there for a few minutes and thought it was ok but as soon as i took the key out the ignition it started again. So now while i type this message my car is sat outside doing the following
Flashing all the lights
Window wipers jerking up and down.
Alarm going off.
The weather has been crap with bad rain and winds and the car is a mk2 ford focus zetec if that helps. Please help me or at least tell me how to disable the horn my neighours aint happy.
Alarm going off.
pull your fuse box out... kill the horn then the wipers
actually after looking @ your small penis thread in the muppet room
i thought you where taking the piss
fable "CRY WOLF"
fable "CRY WOLF"
rog
Sep 4, 2015 12:10 PM
, just disconnect the battery or take the fuses out
