rebuild on turbo engine
Old Jan 1, 2007 | 12:20 PM
westus1's Avatar
westus1
Default rebuild on turbo engine
firstly happy new year guys and gals .I am gong to rebuild my s2 engine but dont know what to do i have a grand for the build any ideas
Old Jan 1, 2007 | 12:50 PM
Eagle's Avatar
Eagle
Super Moderator
lower comped pistons, shot peened rods or new pukka ones. large turbo, front mounted intercooler, ally rad, twin fans, lightened and balanced bottom end, new oil pump. ap organic cutch, chip the ecu and have a nice healthy 230 ish bhp
Old Jan 1, 2007 | 01:14 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
For a grand??!!
ellicoss's Avatar
ellicoss
THINK YOU MIGHT NEED MORE THAN A GRAND TO DO THAT LITTLE LOT
Old Jan 1, 2007 | 01:27 PM
Puss2's Avatar
Puss2
Formerly know as Puss
I can do that for a grand
See you in the morning christian
Old Jan 1, 2007 | 01:30 PM
Christian and Beccy
#1 in Spelling Club
(Now where's that box of old scrap CVH bits......)
Old Jan 1, 2007 | 01:36 PM
Physio's Avatar
Physio
Best thing to do would be to sell you RST, add in the grand that you already have & buy a Subaru wrx, 260 - 280 bhp out the box!!
Quicker than an RST, better looking than an S2 RST, better handling than an RST, more reliable than an RST.......... i could go on all day
Old Jan 1, 2007 | 01:49 PM
westus1's Avatar
westus1
Default rebuild
had a scobby got bored with it old school more fun
Old Jan 1, 2007 | 01:50 PM
Physio's Avatar
Physio
Default Re: rebuild
You cant class an S2 as old school, now if you had a mk2 THAT would be old school
Old Jan 1, 2007 | 01:51 PM
westus1's Avatar
westus1
i aint got an s2 but i have an s1 haha
Old Jan 1, 2007 | 01:53 PM
GARETH T's Avatar
GARETH T
buy a few books on how to rebuild engines properly, not just take them appart,, bang new bearing in, and bolt them back together
Physio's Avatar
Physio
Ahhhhh that's ok then
S1's are so much better looking than S2's but still not old school enough imo
Old Jan 1, 2007 | 01:58 PM
Puss2's Avatar
Puss2
pay no attention to AJ look what he drives
westus1's Avatar
westus1
Default rebuild
dne a few rebuilds before just dnt knw what to go for never tuned a rs was thinking low comps, stge 3 head ,arp bolts ,heavy duty shells and bigger turbo might run over budget but have already got front mount ,cam kit whats you think
Old Jan 1, 2007 | 02:01 PM
westus1's Avatar
westus1
Default rebuild
evo jap crap
Old Jan 1, 2007 | 03:51 PM
Fiecos Dan's Avatar
Fiecos Dan
Std pistons are fine for 250-260+ bhp if tuned well.
But if your going for 210+bhp i think going low comp is best, which a stg 3 head with std pistons will be about 7.9:1 which is perfect.
So if your block is good, and not worn, and pistons are good, then a hone and rings, if not rebore, and new pistons/rings,
shells, gaskets,
ford rst h/g, non strench bolts,
new oil pump and high pressure spring, Ł70 from burton power
new water pump?
new cam belt,
newmans cam kit, and vernier
flywheel skim, and new clutch
Old Jan 1, 2007 | 03:53 PM
Physio's Avatar
Physio
Default Re: rebuild
evo jap crap
Im not the one asking about an engine rebuild
Old Jan 1, 2007 | 03:54 PM
Physio's Avatar
Physio
& you can shut up
Old Jan 1, 2007 | 04:23 PM
smitsturbo's Avatar
smitsturbo
Fiecos Dan
what do you mean by ford rst h/g what does the h/g mean
Old Jan 1, 2007 | 04:28 PM
Fiecos Dan's Avatar
Fiecos Dan
sorry head gasket.
Old Jan 1, 2007 | 06:02 PM
westus1's Avatar
westus1
Default rebuild
cool where the best plce for low comp pistons then so low comp pistons way a stage 3 head is ok
Old Jan 1, 2007 | 06:53 PM
Fiecos Dan's Avatar
Fiecos Dan
If you use a stg 3 head, it will be 7.9 :1 c/r on std pistons and headgasket.
if not, buy new RST pistons, and skim them down, amount needing skimming depends on the c/r you want, and head being fitted.
then get them pressed onto your rods.
Old Jan 1, 2007 | 07:17 PM
Eagle's Avatar
Eagle
Super Moderator
if you look hard enough you can get bargains...
oh and dont forget to fit arp big end bolts ...
was just pointing out some of the things that can be done ... all depends on the condition of the original engine tho..
Old Jan 1, 2007 | 07:49 PM
Fiecos Dan's Avatar
Fiecos Dan
Good point, Arp rod bolts, about Ł50 when i got mine.
Old Jan 1, 2007 | 07:52 PM
smitsturbo's Avatar
smitsturbo
Originally Posted by Fiecos Dan
sorry head gasket.
shit,no no im sorry
Wilsfoci
15
Mar 30, 2016 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
