Will this chip still work with a T34 in my 2WD Sapphire
Old Dec 30, 2006 | 06:42 PM
snow*'s Avatar
snow*
Default Will this chip still work with a T34 in my 2WD Sapphire
Hello lads,
Happy New Year from down here in sunny New Zealand.
I need a little help though, I've just brought a new Garret T34 with a .48 exhaust housing and when I asked about buying a new chip the group in the U.K told me that my old Ahmed Bayjoo chip that I ran with my standard T3 would be fine.
My chip reads 3BL6R24.803 ( 3 Bar, L6 ECU, R24 Ignition curve, 803 injectors)
I'm a little weary of not buying a new chip as I can't see how a T3 chip and a T34 chip would be the same (although I'm a total novice)
The is a quote I pulled from a PM I recieved a year ago from one of the top U.K guys. The below quote is why I'm so confused as the place I've brought the T34 tell me differently (I would trust the guy in the below quote more though.
The chip is a very old one, which is for: 3B = 3 bar MAP sensor, L6 = Level 6, R24 is the ignition curve and this gives 10° on the top line and is designed for STANDARD cams. It will be fuelling wrong with any others. Obviously 803 is the injectors. This chip is not suitable for anything other than standard compression / T3.
Any ideas or help would be most appreciated,
Cheers,
Ollie
Old Dec 30, 2006 | 06:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Hi Ollie,you'll need a new chip m8,i got mine from MSD with closed loop .
Old Dec 30, 2006 | 07:02 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
They told you the chip will be fine to encourage the sale.
It wont be.
Old Dec 30, 2006 | 07:11 PM
snow*'s Avatar
snow*
Cheers fellas.
I guess that could have been a disaster
So obviously I'm not going to buy a new chip from them.
Who would you guys reccomend then?.
As there's no Cossie tuners down here in New Zealand I'd want the chip to be as close to my car specs as possible.
1988 2WD Sapphire.
83,000 Miles
Bosch 803 Injectors
3 Bar Map Sensor
-31 Actuator
Pace RS500 Spec Intercooler
Pro Alloy Turbo Cooler
Pro Alloy 50mm Radiator
T34 with .48 exhaust housing and 360 degree thrust bearing
Group A coil, Blue Beru Motorsport leads
Group A Bosch Fuel Pump
That's pretty much the spec of my car.
Cheers,
Ollie.
Old Dec 30, 2006 | 07:13 PM
KSA-Cossie's Avatar
KSA-Cossie
Phone stu at MSD and he'll sort you out m8.
Old Dec 30, 2006 | 07:40 PM
snow*'s Avatar
snow*
Cheers Kev.
I'm in a bit of a qwandry with regards to my brakes as well.
I'm going with Ferrodo DS2500 pads all round.
But I'm not sure whether to go for Tarox drilled and gooved disks, or just 40 grooved.
Or the my other option is some German TUV approved drilled and grooved or 8 grooved
Which is a better brand etc?
What do you guys think (note I'm using my standard 15" wheels hence no AP or Hi-Spec kits
Toe Knee
Aug 23, 2015 08:31 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Escortdriver1
Aug 19, 2015 09:02 PM
Old ford
Jul 31, 2015 06:50 AM
