S1 Boosting Question....
was bored at work today, so cleaned up my metering head, and decided to connect my boost gauge up and see what it was boosting at as it felt a bit slow (compared to the cossie anyway!). So went for a drive, and wait for it........
Its boosting at a MASSIVE 4psi.
DOH!
SO, can i just shorten the actuator rod to get it up again. The cars totally standard and not been mucked with, so maybe the actuators gone weak? at full throttle, its smells of petrol quite a bit too.
if so, is it 2 turns for 1 psi as cossie actuator?
Cheers!
Mike
DOH!SO, can i just shorten the actuator rod to get it up again. The cars totally standard and not been mucked with, so maybe the actuators gone weak? at full throttle, its smells of petrol quite a bit too.
Cheers!
Mike
wooooow! amazing boost. Mines running so much better since i cleared it out and cleaned the sensors. Its idleing much better, so im gunna have a go.
actuator looks like a twat to get to though.
actuator looks like a twat to get to though. 20K+ Super Poster.
it might be that the amal valve's not activating.
4psi sounds right from a standard actuator set up correctly. you acheive the higher boost from the amal valve bleeding off some of the air
check if your amal valve is clicking
Originally Posted by TIFF
I had a mega 8psi on mine once Karl had set it up
You dont want big Power S1's............Just keep them Standard
sod that! gonna crack mine round to 2.2 bar when all done and running
Steve.
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
