what do people rate as the best "fast road" pad?
for road use and the occasional track day.
i'm tempted to throw my brakes in the bin and start again, just want to hear people's opinions
Best road/track pad IMO is Ferodo DS3000 they are harsh on your disks & create a lot of dust, but STOP incredably well either hot or cold.
For a less harsh pad I rate Ferodo DS2500 or Mintex 1144.
its currently running DS2500s with aftermarket drilled/grooved discs
i have some issues with the brakes constantly squeaky, sounds/feels like metal on metal grinding when braking from high speeds.
and after just 2 laps of donno i was getting so much judder thru the steering wheel it was unreal! (heat related, they were fine after a cool)
sum1 on the BMW forums just said that he knows a LOT of peopl ehaving identical heat/judder issues to me with DS2500s and swapping pads cured it.
Hi Jim
the juder is cause from your discs , they are warped under heat and heavy braking
you need thicker discs that would be a start , the ds2500 are kind of light racing pads they do cause alot of heat
marco
I've experienced similar with DS2500's however it was down to being a pussie with the brakes & not stamping on them.....the judder was so bad at one point the steering wheel was shaking.......a few corners later Propperly standing rather than trailing & they were fine.
Worth a try before you bin them
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
