URGENT help needed. My s1 wont run.....
Old Dec 29, 2006 | 04:30 PM
boXXer's Avatar
boXXer
GASH!
Default URGENT help needed. My s1 wont run.....
Hello, wondering if anyone can help me as im now stuck at work.
Went to start the s1, and it run for about 3 secs, then just died out. now, whenever i crank it, it runs for about 2 secs, then dies out completely, even with my foot flat on the floor. Its sucking air, and there is no smell of petrol.
The fuel pump is priming, and i have half tank of fuel, so im pretty sure its not them. Any quick help would be good.
Mike
Old Dec 29, 2006 | 04:32 PM
Billabong's Avatar
Billabong
Check for air leaks, and is the oil cap on okay?
BigErn's Avatar
BigErn
Give the metering head a "tap", my mates kept doing this so he used to carry a screwdriver to hit it with. Good luck mate.
Old Dec 29, 2006 | 04:48 PM
boXXer's Avatar
boXXer
GASH!
tried them, didnt work. Anyone?
Old Dec 29, 2006 | 04:54 PM
Billabong's Avatar
Billabong
Are you absolutely sure a boost hose hasn't come off slightly, or split?
Old Dec 29, 2006 | 04:56 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
fuel pumps priming, but does it run when cranking and car running?
Old Dec 29, 2006 | 05:00 PM
TIFF's Avatar
TIFF
Chasing Radders
Metering head
Old Dec 29, 2006 | 05:04 PM
smitsturbo's Avatar
smitsturbo
i would say either the metering head or hose/pipe has split or came off if not lets try some over time while we wait
Old Dec 29, 2006 | 05:07 PM
boXXer's Avatar
boXXer
GASH!
right, it starts every time, but runs for no longer than 2 seconds. tried all connections, and they dont work. what can i do to the metering head to check?
Old Dec 29, 2006 | 06:57 PM
Bungle's Avatar
Bungle
Right as daft as it sounds my mate had this on my old series 2 and the pipe had comne off either the actuator or the turbo housing as the bleed valve came un clipped and the bleed valve being heavy the weight of it had pulled the pipe off hope this helps cheers, Grant
Old Dec 29, 2006 | 08:21 PM
ricky_3dr's Avatar
ricky_3dr
Got it sorted????
Old Dec 29, 2006 | 09:27 PM
the benno's Avatar
the benno
fuel pump relay ??????????????
Old Dec 29, 2006 | 09:51 PM
SI-S1's Avatar
SI-S1
i had that prob on my S1 was the silver relay
Old Dec 29, 2006 | 10:03 PM
yer's Avatar
yer
Boxxer its Alan s1 Remove the hose from the bottom of the metering unit see if it has fuel in it thats whot mine was doing
Run then it lost preasure in the as a Gaskit goes
If you still have my number give me a call im working untill 3am
Old Dec 29, 2006 | 10:48 PM
boXXer's Avatar
boXXer
GASH!
RIIIIIIIIGHT! back at home now, lol. I took off ALL the sensor clips, and cleaned them out, and made no difference, so turned to looking at the metering head, and took the air filter off. There was a small amount of fuel in the bottom. So i moved the plunger up and down about 50 times, then tried to start the car. It didnt go first time, but went and ticked over on its own. So refitted the filter, and now its running better than ever. Weird. The ultimate test will be in the morning and starting it from cold, as thats when it used to be at its worse.
Can you overhaul those MFI systems?
Cheers for all ya help
Mike
Old Dec 29, 2006 | 10:49 PM
boXXer's Avatar
boXXer
GASH!
where is this relay? is it on the inner wing on the passenger side? as i saw that. Does it have a fuse in the top of it?
Mike
Old Dec 29, 2006 | 10:50 PM
boXXer's Avatar
boXXer
GASH!
Originally Posted by ricky_3dr
Got it sorted????
yeah for now! lol. Wanna come over and set it on fire?
Old Dec 30, 2006 | 11:55 AM
ricky_3dr's Avatar
ricky_3dr
Got it sorted????
You don't mean that That's what ya get for messing about with old Fords
Old Dec 30, 2006 | 12:10 PM
xr2i-carl's Avatar
xr2i-carl
Old Dec 30, 2006 | 12:35 PM
boXXer's Avatar
boXXer
GASH!
indeed. Piles 'o' shite. Got to fix the 3dr now.
Old Dec 30, 2006 | 12:38 PM
TIFF's Avatar
TIFF
Chasing Radders
You want to stick a Cossie Fuel pump on it mate........
Got one for sale if you want
Old Dec 30, 2006 | 12:43 PM
boXXer's Avatar
boXXer
GASH!
do they help? how much you wanting?
Old Dec 30, 2006 | 12:44 PM
TIFF's Avatar
TIFF
Chasing Radders
Karl advised me to fit a Cossie one
Ł30 if you want it
Old Dec 30, 2006 | 12:57 PM
Jay,'s Avatar
Jay,
Sponsor
if that prob shows up again change the silver/grey relay should cure it
Old Dec 30, 2006 | 01:09 PM
boXXer's Avatar
boXXer
GASH!
where is this relay? in the fuse box?
Old Dec 30, 2006 | 02:39 PM
gus's Avatar
gus
relay is under the dash, steering wheel side
Old Dec 30, 2006 | 02:52 PM
boXXer's Avatar
boXXer
GASH!
and what does it do?
Old Dec 30, 2006 | 02:53 PM
Jay,'s Avatar
Jay,
Sponsor
fuel pump relay
Old Dec 30, 2006 | 02:55 PM
boXXer's Avatar
boXXer
GASH!
ah right ok. Cheers chaps!
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
