Trouble burning AVI files
Old Dec 28, 2006 | 12:13 PM
Thrush's Avatar
Thrush
Irritating c........
Not sure - not had it do that to me...
What write type are you trying? MAKE DATA CD should be the way you want to do it.
If it still won't work, you could always use MAKE DATA DVD and put it on a DVD......
Old Dec 28, 2006 | 01:19 PM
ballin's Avatar
ballin
that would be why then, avi files need to be burnt as data cds.
dont think you can get them to play on (most) dvd players without converting them back to DVD format iirc.
else just buy a £30 dvd player which supports avi files (and divx/xvid codecs built in etc) ie. the chili dvd player, ive yet to find a format it wont play
Old Dec 28, 2006 | 01:25 PM
gal_racer666's Avatar
gal_racer666
vcd's only play on the very cheap and few dvd players. alsdo have you tryed dvd shrink. it may help. we have a few programs we use.
better off to write as a dvd and if ya cant get it to work write it as a vcd (video cd)
Old Dec 28, 2006 | 01:35 PM
Hockney's Avatar
Hockney
DVD Shrink wont burn avi's. All DVD Shrink does is compress full dvd's (dvd9) to backup onto a 4.7gb (dvd5) dvd disk.
If the avi you have is on for more than 80mins then it wont fit onto a cdr as a vcd as I'm guessing yours is with it turning out at 900Mb. You will need to split the 900Mb vcd into 2 parts and burn each of them onto disks, to fit on one 80 min cdr you need to encode it to kvcd if it's more than 80mins long or you could just use Nero Vision Express to encode the avi to dvd format and burn it onto a dvd.
Old Dec 28, 2006 | 03:00 PM
Hockney's Avatar
Hockney
It's not all about quickness it's about quality. WinAVI maybe fast but it's shit. Nero's Vision Express turns out half decent avi to dvd's but make sure you tick the 2 pass encode
Old Dec 28, 2006 | 03:06 PM
Thrush's Avatar
Thrush
VCD's don't only play on cheap and few DVD players. Every DVD player I have had plays VCD's including my current (NOT cheap) Sony machine, so your info there is wrong...
DVDShrink won't be of any help here at all as the filetype is an AVI. DVDShrink is used for two things : 1) ripping a DVD to the PC (breaking encryption) and 2) shrinking the filesize of the DVD files to below 4.5gb so they can fit on a DVD-R. SO again, your info here is wrong.
And you can't write it a a DVD unless you use a programme to encode the friles from AVI to DVD.
Old Dec 28, 2006 | 03:12 PM
Thrush's Avatar
Thrush
Matt - what you need to find out first is if your DVD player supports DivX playback.
Burn the AVI you have to either CD or DVD as a DATA DISC using nero. Then just put the disc in the DVD player and see if it will read and play the AVI. Some do, some don't....
If that doesn't work, then you don't have DivX support on your player, and you will need to encode to a different format to get it to play.
VCD is shit - I used to encode video clips and the like the VCD using Nero but the quality is just shocking - nothing like the KVCD's you can get hold of on the net
You are best off converting to DVD format using an AVI to DVD converter or Nero Vision Express as Hock says. Get yourself a DVD-RW disc and you can burn stuff, watch it, then erase the disc to reuse it again next time - is what I do
Old Dec 28, 2006 | 03:18 PM
Hockney's Avatar
Hockney
Tis what I do saves having loads of dvd's/cdr's laying about that you'll probably never watch again
Old Dec 28, 2006 | 04:20 PM
Thrush's Avatar
Thrush
Thought you did have a TV Matt, but no aerial so can't watch "TV" as such, but used yours for dvd's and video games?
Old Dec 28, 2006 | 09:24 PM
Stu.H's Avatar
Stu.H
pc > tv out
get a cheap laptop, then u havent ever gotta burn anythng ever.
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Bransby
Sep 21, 2015 05:29 PM
