How do i download faster?
i've got a problem with downloading,basically it takes forever
my connection is 3mb+ i reckon,but when downloading it only does about 18.5kb/sec......surely it should be quicker
are there some settings somewhere to change?
Is your connection optrimised?... the default XP is not optimised for DSL try optimising your net connection, It can be done by hand though registry tweaks or with an application such as TCP/IP optimiser. I would not suggest messing with the settings however unless you know what you are doing... you can also download 'patches' which do these changes for you
http://www.speedguide.net/downloads.php
thanks for the replies people, my PC is quick in normal use,i have plenty of RAM and i always clear out cookies etc on a regular basis (i also only run programs i use regularly so i disable the others in msconfig)
i'm on about general downloading of videos from websites (not torrent sites)
i downloading an 88mb file last night and it took ages!!
i'll give my ISP a call too
All depends on how much bandwith the servers are giving out too you when downloading from sites. Try Microsoft and download something from there and see what your speeds are like. You should be able to max out your download speed from Microsoft
apples24
Jun 20, 2004 02:12 PM
apples24
17
Jun 19, 2004 03:29 PM
Andy_R
Jun 2, 2004 04:01 PM
