Any bodyshop people LOOK PLZ
Old Dec 27, 2006 | 08:59 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default Any bodyshop people LOOK PLZ
what's best for removing overspray
bought a little run-around and its got overspray on it
what do you recommend
thanks
Old Dec 27, 2006 | 09:03 PM
Ginge !'s Avatar
Ginge !
just finding my feet
tcut works well or g3,,,,,, but im no body shop person
g3 is a compound polish and makes the whole car mint again
get the car mopped for about 70 quid and just smile at all your hard work ( driving car to bodyshop for a mop)
mercury grey minter's Avatar
mercury grey minter
A product called FINNESSE IT.Rub on with a cloth and overspray diisapears.It less abrasive than T-CUT.Could use T-CUT as a cheaper and quicker option,just be careful you don,t go mad with it as it will take a few layers of paint off.Also G3 is a very abrasive cutting compound.Our body shop uses FINNESE IT for overspray.Think you can get an something similar from HALFORDS.
Old Dec 27, 2006 | 09:07 PM
392B.H.P.SAFF
looks like a trip to halfords tomoorow then
thanking you
Old Dec 27, 2006 | 09:12 PM
mercury grey minter
thanking you
Just look out for a FINISHING COMPOUND...not a CUTTING COMPOUND.
Old Dec 27, 2006 | 09:18 PM
392B.H.P.SAFF
mercury grey minter
top man thankyou
Old Dec 27, 2006 | 09:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
G10 is much less abbrasiv than G3
your sposed to mix em with 6 parts water to make a runny paste
personally i would go to a car paint supplier, not halfords
Old Dec 27, 2006 | 09:32 PM
coswurv's Avatar
coswurv
It depends how bad the overspray is, if its really bad then gently go over the panel with 2000 gritt wet and dry paper until the panel is smooth and free of overspray but gently dont rub through the laquer, then after that a go over with g3 and finnesse on a mop to finish it off and it will look mint again.
Old Dec 27, 2006 | 10:34 PM
snedboy's Avatar
snedboy
Sorry but NEVER had to do that for overspray!!!!!!
Use G3 if its bad or as said above Finnesse It
Old Dec 27, 2006 | 10:41 PM
coswurv's Avatar
coswurv
Well like i said it depends how bad the overspray is ive only ever had to do it twice in 35 years of spraying as g3 isnt always tough enough to ripp it off especially if its been like this for a long time cheers.
CraigoScott's Avatar
CraigoScott
some aggressive clay bars can be used to remove overspray, but can marr paintwork, but if your not stupid this can be avoided, take a look on www.detailingworld.com and see what you can find on claying your car
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
rsguy
44
Sep 29, 2015 03:29 PM
Si B
Sep 12, 2015 06:49 AM
