Crank Pulley
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Probably a silly question but:
How do you get the crank pulley off? I thought maybe jaming a screwdriver or somthing through the pulley and onto the engine, to stop the pulley turning?
The engine has the crank pulley with the 3 threaded holes in it. And the car is off the ground with no back brakes. so cant lock up the transmition.
Any ideas??
Bruce
Any ideas??
Bruce
thanks claude,
I was going to try jaming the flywheel in some way. Thought there may have been a significance to the 3 threaded holes on the crank pulley.
Bruce
Bruce
Yeh thought it could have been for a type of puller.
That will be the correct/Ford way of removing the pulley. Not using a screwdriver in the flywheel lol.
Cheers guys
Bruce
Cheers guys
Bruce
once you have the crank pulley bolt undone you will still more than likely need a puller to remove the pulley, hitting it is not a good option as they have a habit of breaking in half, they sometimes even do this when using a puller but a puller would be the best bet once you have removed the bolt
DixieTheKid
11
Jun 6, 2020 11:20 AM
jonfoc
16
Sep 11, 2018 05:35 PM
timsrs
22
Sep 24, 2015 08:14 PM
