fuel pump relay
Old Dec 19, 2006 | 04:57 PM
ryanayr123's Avatar
ryanayr123
Default fuel pump relay
can someone help me please...where is the fuel pump relay on a 1990 escort rs and wat colour is it
Old Dec 19, 2006 | 05:02 PM
grsford's Avatar
grsford
under the dash near the throttle pedel and its the pink one
Old Dec 19, 2006 | 05:11 PM
ryanayr123's Avatar
ryanayr123
cheers mate
Old Dec 19, 2006 | 05:15 PM
ryanayr123's Avatar
ryanayr123
does anyone know how to change it.does it have wires going into it
Old Dec 19, 2006 | 05:23 PM
xrmalin's Avatar
xrmalin
it should just pull out if you take the air vent out nxt to the steering wheel you should get a better view of it.
Old Dec 19, 2006 | 07:58 PM
SafeChav's Avatar
SafeChav
As above.
Whats the problem you are having?
Old Dec 20, 2006 | 04:29 PM
ryanayr123's Avatar
ryanayr123
wont start..just keeps turning over just wont kick to get it started..was told it could be the fuel pump relay
Old Dec 20, 2006 | 06:34 PM
xrmalin's Avatar
xrmalin
If you hear the fuel pump prime when the ignitions turned on its not that thats playing up.
I think
Old Dec 20, 2006 | 07:18 PM
SafeChav's Avatar
SafeChav
I think
Not necessarily........
Is the pump not running when you crank the engine over then?
Old Dec 21, 2006 | 08:00 PM
ryanayr123's Avatar
ryanayr123
no sure..dont really know wat to lookout for or listen too
Old Dec 21, 2006 | 09:34 PM
SafeChav's Avatar
SafeChav
You will probably need your glamorous assistant to listen out or turn the engine over.
Can be hard to hear, just a faint buzzing.
Check for that first and get back to me
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
