Actuator test--need help
Hello
My car doesnt wont go under 0.5 boost, I try to shortened wastegate arm to maximum but nothing.
How can I check if my actuator work?
Thank you
Thank you
take the actuator off and see if u can pull the rod by hand and if u can with no preasure that means ur actuators fuked had the same problem
the rod shud be hard to pull out and stiff
Dragsteer
The standard actuator will not give more than 0.5bar without an amal valve. To test if the amal valve is working - unplug it. If your boost does not go DOWN, then it isn't working. Your actuator could be fine.
thanks. but I today "test" actuator, i blocked hose from turbo and car going good. I think actuator leaking air much.
and how will I unpluged amal? just push out power? and try get boost, if will be same thing with power on amal, means it is fault?
sorry bad english
sorry bad english
JK12
33
Apr 26, 2021 12:09 PM
