Fuel Cap
Old Dec 16, 2006 | 01:15 PM
Brian's Avatar
Brian
Default Fuel Cap
The fuel cap on the Series 2 is a bit tight getting on and off i have sprayed WD40 where the key goes and a load of rust has come out
Can these fuel caps be stripepd down or is it better just to get a new one?? If i get a new one can i use the same lock so i dont have loads of keys on the key ring??
Brian
Old Dec 16, 2006 | 01:20 PM
dave_y's Avatar
dave_y
you can take the lock mechanism out and get a new fuel cap yes.
Old Dec 16, 2006 | 01:31 PM
Brian's Avatar
Brian
Is it easy to do??
Brian
Old Dec 16, 2006 | 01:36 PM
dave_y's Avatar
dave_y
the mechanism comes out from the front of the fuel cap (away from the car if it were in position)
i cant remember if you can push it out from the back or not, has been a while since i rebuilt mine.
the easy option is to cut the fuel cap off the locking mechanism with a dremel or something! proper butcher style
Old Dec 16, 2006 | 04:39 PM
Small circlip on the back of the lock ,prise this off, with the key in the lock slide out of the cap, job done ,you may just need to get some lubrication in there when its apart
Old Dec 17, 2006 | 07:26 AM
Brian's Avatar
Brian
Cheer's Twins will have a look at it during the week
Brian
Old Dec 17, 2006 | 04:04 PM
SafeChav's Avatar
SafeChav
Be careful while its stiff, the MK4 keys are very prone to twist inside the plastic handle, then you end up with your keys stuck in the petrol cap
Old Dec 17, 2006 | 05:04 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Learnt that the hard way
Old Dec 17, 2006 | 05:17 PM
SafeChav's Avatar
SafeChav
looking back though its always amusing to think you were walking across the forecourt with the petrol cap in your hand while everyone is looking and thinking lol
Old Dec 17, 2006 | 07:12 PM
©hatter Box's Avatar
©hatter Box
6175362 thats the number you need only 13 pounds
Old Dec 18, 2006 | 12:16 PM
Smiggy's Avatar
Smiggy
I've been that soldier, right pain in the arse. Ended up taking it up to the garage near my work stripping it and leaving it in a basin of used engine oil for about a week. Worked a treat...... well until the next time it happened.
SMG
Old Dec 18, 2006 | 12:17 PM
SafeChav's Avatar
SafeChav
Ive never had that one happen to me personally thankfully, it was always my mum PMSL
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
biggiejody
Sep 19, 2015 10:25 AM
shoppel
Ford Escort RS Cosworth
Sep 17, 2015 09:03 AM
