Stage 3 Turbosystems/NMS ECU
Software developed by Karl and coded by Tony at Turbosystems.
Please note, that this NOT suitable for anything smaller than a stage 3 turbo with 0.48 housing - the car will det it's bollocks off. Engine must be a 1600CVH - no ZVH.
No rev limit, no boost limit. This is not a piggy back chip, but the original reprogrammed with a totally different ignition map.
It's designed to spool up big turbo's quicker, and it works! There is also more top end advance to increase power on high revving engines. ECU needs a knock sensor.
This is ECU is TOTALLY different in chacteristics to anything else out there. I'm selling because i'm going to custom management.
The car WILL need a setup with this ECU - i can do this for you if you're local.
£120 delivered.
£120 delivered.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
JK12
33
Apr 26, 2021 12:09 PM
Mc5506
Oct 5, 2015 09:57 PM
