wastegate chatter on a t25 escort cossy
Sep 1, 2004 | 09:55 PM
will i get any wastegate chatter if i fit a cone filter to my small turbo escos, bored of the quietness of the car now and don't want a dumpvalve
Sep 1, 2004 | 09:57 PM
Sep 1, 2004 | 10:02 PM
I would doubt it as well, as wastegate chatter does not exist
you might however, hear the turbo surging
Sep 1, 2004 | 10:04 PM
how do get that chatter sound then ??
Sep 1, 2004 | 10:07 PM
i get that "chatter" sound on mine and i run a k+n cone filter
Sep 1, 2004 | 10:08 PM
Whats standard boost on these about 10 - 11 psi
Sep 1, 2004 | 10:13 PM
8ish
cheers peeps. boost gague is next on my list cos the standard one is pretty useless.
Sep 1, 2004 | 10:16 PM
8ish i run 10psi on cast pistons and 10.5.1 compression for some reason i thought they were higher.
Oh well you live and learn
Sep 1, 2004 | 10:18 PM
Sep 1, 2004 | 10:20 PM
10.5:1?????? are you sure???
std c/r on cossie is 8.1:1
Sep 1, 2004 | 10:24 PM
No, not cossie Sierra dohc 8valve turbo 10.5.1 compression 10psi 200hp.(T25)
Ł10.00 to fix when anything goes wrong / Ł20.00 if you need a second hand complete engine.
Sep 1, 2004 | 10:30 PM
swap u 4 a 3 door that chatters well
Sep 1, 2004 | 10:32 PM
Quote:
funny really as he just sold a ringer to get the escort
Sep 1, 2004 | 10:35 PM
nice 1 ary, i'll have it back as the escort is boring
Sep 1, 2004 | 10:36 PM
I did on my small turbo with cone
Sep 1, 2004 | 10:38 PM
may be a ringer, but the back end is straight
Sep 1, 2004 | 10:39 PM
cheers dunc, what filter did u have. i'm thinking of a pipercross foam jobbie
Sep 1, 2004 | 10:42 PM
doh walked into that one
or is that reversed
here u go ary, pic 4 ya
Sep 1, 2004 | 10:48 PM
Sep 1, 2004 | 10:52 PM
They have them lil recirc dumpvalve things attatched to the compressor housing on T25 esc cossies dont they? Will need to blank that off, get a cone filter, and should have decent-ish chatter
nice 1 AJ, does the k&n come with an adapter plate for the filter
Sep 1, 2004 | 10:56 PM
not that i know of m8 got mine of a user on here its the ggr item
Sep 1, 2004 | 11:01 PM
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
stickyslick
14
Aug 10, 2015 06:27 PM
