Setting up a -31 actuator, help please
Old Dec 14, 2006 | 10:54 AM
Paulo P's Avatar
Paulo P
Default Setting up a -31 actuator, help please
Hi
I've got a stage 1 chip and -31 actuator to install to my car. I'm going to set it up to run 14psi in 3rd gear to be safe but I don't know what a good starting point is to work from. I don't want to accidently start off with too much boost obviously I'm used to setting up boost using dawes devices etc but I've not done one on an actuator before.
Any tips please?
The car is a 2 wheel drive sapph running a standard t3
Thanks
Old Dec 14, 2006 | 05:25 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Just put it on as normal, then run it up to check what its running, if to much boost lengthen the rod, if too little shorten the rod, remember dont over do it as you dont want it overboosting, one full turn till you get close then half turns
If your unsure take it to a local tuner and theyll do it no problems
Old Dec 14, 2006 | 05:29 PM
2001ode's Avatar
2001ode
Hi,
That is preset of waste gate : 1/2 hole.
And go to a road test to finalyse.
Regards.
Claude
Old Dec 14, 2006 | 05:33 PM
NUTTIN RILLA
I sat for ten minutes trying to explain that mate but it sounded so confusing, i like your picture
Old Dec 14, 2006 | 06:24 PM
Paulo P's Avatar
Paulo P
Cheers guys Going out tonight with a gauge in there first to see what the car is running now then i'll pop the chip in at the weekend and fit the actuator
Old Dec 14, 2006 | 08:29 PM
Paulo P's Avatar
Paulo P
I am happy to report that with a boost gauge fitted tonight the car is indeed running the standard boost pressure Roll on 14 psi!
I am still amazed at how well a standard car goes! My mate who is an evo 6 owner was a little scared and impressed tonight when he was reading the gauge for me
Old Dec 14, 2006 | 08:46 PM
NUTTIN RILLA
Good stuff mate remember and be carefull tho, i blew my car up when it was stage 1
I was flat out in fourth gear tho and i had hit every rev limiter until fifth
Old Dec 14, 2006 | 10:02 PM
Sideways_Sierra's Avatar
Sideways_Sierra
Ill be making mine stage 1 soon. got a -31 already on the car, but a stage1 chip in me toolbox waiting
Old Dec 17, 2006 | 02:08 PM
Paulo P's Avatar
Paulo P
I've just been out trying to set it up and even with the rod lengthened to where it just slips over the wastegate I'm still seeing 1.1-1.2 bar This is only for very brief periods.
What am I doing wrong? Can I keep lengthening the rod?
Old Dec 17, 2006 | 02:57 PM
Paulo P's Avatar
Paulo P
I've now lengthened the rod 1 more turn so that now it's opening the wastegate but that's making the car very laggy and then still producing too much boost when it finally makes good boost What's going on here?
It's doing my head in
Thanks
Old Jan 3, 2007 | 12:55 PM
cozmeister's Avatar
cozmeister
More boost Igor!
From the Cosworth workshop manual:
    Old Jan 3, 2007 | 01:26 PM
    costina's Avatar
    costina
    Live long and prosper!!
    Thought u had Garys 4x4 Paul not a 2wd???
    good luck
    Old Jan 3, 2007 | 01:54 PM
    Paulo P's Avatar
    Paulo P
    Mine is a 2 wheel drive I haven't had chance with this rubbish weather to look at the car for ages now so it's just sat on my drive I hope to refit the chip and actuator and try again but everytime I think of doing it, it goes and pisses down with rain
    Old Jan 6, 2007 | 12:24 AM
    BigErn's Avatar
    BigErn
    Thanks
    I had a simlar experience with a stage 3 2wd, on its -34 it was boosting 23psi and holding 13. I thought it was actuator trouble and bought a new one but it would boost to 30psi and hold 20 after fitting a new actuator (Forge with white spring) no matter where the rod was. The only thing I could think was a duff actuator, never found out as I sold the car.
    JK12
    33
    Apr 26, 2021 12:09 PM
    steve.rst
    Mar 15, 2016 08:01 AM
    A.t.p
    Sep 29, 2015 05:04 PM
    rs_jim
    Sep 19, 2015 08:41 PM
    wheelwizardrefurbs
    Sep 18, 2015 02:39 PM
