whats wrong
Dec 13, 2006 | 04:56 PM
whats wrong
when i start my car from cold i have to keep the revs at 1500-2000 for the car to tick over after its warm its ok any ideas
Dec 13, 2006 | 06:13 PM
good chance its the thermo time switch mate just under the inlet manifold or bad connection to it.
Dec 13, 2006 | 07:28 PM
Quote:
No......will be nothing to do with that and i can GUARANTEE that.
Chances are you have an air leak. Brake servo would be a prime suspect.
Dec 13, 2006 | 07:46 PM
cool how will i know if its a air leak
Dec 13, 2006 | 08:01 PM
Disconnect the brake servo, block the hole off and see if it idles when cold.
P.S for fuck sake dont try and drive it
Dec 13, 2006 | 09:17 PM
Dec 23, 2006 | 09:16 PM
checked it out the plug that goes into the crossover pipe had broken cables so i replaced them and the screw that on the thottle body next to the choke fell out today so i suspect its lose so i put it back in and it seems to be running fine anyone no what the screw is
Dec 23, 2006 | 09:25 PM
Does the screw face down towards the ground and have a spring on it?
Dec 23, 2006 | 09:27 PM
Dec 23, 2006 | 09:31 PM
that screw will adjust the idle speed up and down, if it fell out, then it is adjusted right out and shouldn't tick over, so you need to put it back in and adjust the idle speed correctly when the car is up to full running temperature.
Dec 23, 2006 | 09:35 PM
cheers thats what i thought that what it was cause it was idleing like a shit heap like the fiesat by the way
Dec 23, 2006 | 09:37 PM
hey no worries cheers dude.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
DavidK
Sep 27, 2015 02:55 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
