GReedy Boost Controllers
Old Dec 12, 2006 | 09:09 PM
Maxxeh's Avatar
Maxxeh
Default GReedy Boost Controllers
Will i be able to use the GReedy Electronic Boost Controller on my ERST, which is running MFI? I was looking at the Profec B II.
Does it replace anything?
Thanx
Old Dec 12, 2006 | 10:12 PM
marky_g's Avatar
marky_g
Fleet Manager
think its ecu based mate so u may have to go efi
Old Dec 12, 2006 | 10:18 PM
Maxxeh's Avatar
Maxxeh
can you not use any electronic boost controller with MFI?
Old Dec 12, 2006 | 10:27 PM
marky_g's Avatar
marky_g
Fleet Manager
dont think so mate, never seen one on anything mechanicaly powered erst, r5, uno turbo, etc
only on efi cars like 200sx's, skyline's, punto's, gtir's
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Boost Controllers don't need to be ECU linked. They generally only need power/earth and connections to the valve, just like you would connect a bleed valve. Also a map signal, which is connected just like you connect a boost gauge. Some have additional features which may need input signals to use all the functionality. The Profec-B isn't one that needs other stuff to make it work.
The AVC-R can display Injector Duty, RPM etc, so needs a wire for these.
Old Dec 12, 2006 | 10:31 PM
Maxxeh's Avatar
Maxxeh
Are there any certain boost controllers you guys would recommend? Which ones are people using out there with MFI?
Am i right in thinking that the boost will not fluctuate, Compared to the bleed valve.
Old Dec 12, 2006 | 10:34 PM
Christian and Beccy
#1 in Spelling Club
Using a boost controller doesn't guarantee that the boost won't fluctuate. It really depends on the quality of the rest of the set-up and how much you are asking of it.
For example, if you only have a 7psi actuator and you want to make 25psi, the controller will struggle.
The Profec-B is a simple, no-frills, good quality boost controller, but don't expect it to work miracles. It mainly makes it much easier to control boost from inside the car, however, it will be more accurate and stable than a bleed valve.
Old Dec 12, 2006 | 10:49 PM
marky_g's Avatar
marky_g
Fleet Manager
well i just shut the fuck up
Old Dec 12, 2006 | 11:09 PM
Maxxeh's Avatar
Maxxeh
you cant use the fancy fuctions on the boost controllers with MFI am i rite?
Old Dec 13, 2006 | 06:57 AM
Christian and Beccy
#1 in Spelling Club
If you can give it a speed signal (by using an EFi sender, which fits between the gearbox and speedo cable), then you can display speed on a controller that has this feature, for example.
Some stuff, you just can't solve. I imagine that Injector Duty is something that you can't do on an MFi car.
Old Dec 13, 2006 | 11:11 PM
Maxxeh's Avatar
Maxxeh
Is it best to go for the GReedy Profec B II ? i heard its very simple to use.
Old Dec 14, 2006 | 12:05 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
It is very easy to use.
Oh, and a little side note... I will be selling mine in a couple of weeks
Old Dec 14, 2006 | 02:56 PM
turboloon's Avatar
turboloon
my mates got eletronic boost controller on his r5gtt i think it's a greddy model
Old Dec 14, 2006 | 04:28 PM
rstdave's Avatar
rstdave
Greddy's ideal for simple boost control...saved me loads of hassle messin around with bleed valves!! As said, it's simple and easy to install and in my case made the boost alot more stable! Mine peaks and holds the same boost all the way through the rev range now
Old Dec 14, 2006 | 05:23 PM
Maxxeh's Avatar
Maxxeh
rstdave thats the exact reason why i want one
how easy is it to install?
Old Dec 15, 2006 | 02:19 PM
Tony Turbo's Avatar
Tony Turbo
Piece of piss.
From memory... a Live and an Earth to thr unit, a plug on to the solenoid and some boost tubing going to the back of the unit so it can read boost pressure.
Old Dec 15, 2006 | 03:00 PM
Maxxeh's Avatar
Maxxeh
kewl cant wait to get one now
Old Dec 15, 2006 | 03:04 PM
G420 DEL's Avatar
G420 DEL
i think the excitment made you forget how cool is spelt
Old Dec 15, 2006 | 03:05 PM
Christian and Beccy
#1 in Spelling Club
....and in your excitement, you forgot how excitement is spelt!!
Old Dec 15, 2006 | 03:06 PM
G420 DEL's Avatar
G420 DEL
ERROR
Old Dec 15, 2006 | 06:17 PM
rstdave's Avatar
rstdave
As tony turbo said.......easy to fit (anyone with half a brain could do it)!!! There's a surprisin amount of functions on it so u'll need to read the manual pretty thoroughly, and go careful not to fuck around with the settins too much as u can mess it up and end up with boost spikes etc!!!
Old Dec 16, 2006 | 04:17 PM
AndyRST's Avatar
AndyRST
Oh will you now?
Old Dec 16, 2006 | 05:01 PM
Tony Turbo's Avatar
Tony Turbo
Oh will you now?
Yeah, I'm sure I'll sell it to some cunt for a cut throat price
Old Dec 16, 2006 | 09:21 PM
DanRSturbo's Avatar
DanRSturbo
Oh will you now?
I'm working 90 odd miles away and even I knew that
Old Dec 16, 2006 | 09:53 PM
AndyRST's Avatar
AndyRST
Oh will you now?
I thought the deal was done, and im a lucky cunt?
Oh and it was try before you buy wasnt it ?
Oh Dan read above
Old Dec 17, 2006 | 03:41 PM
Tony Turbo's Avatar
Tony Turbo
Old Dec 17, 2006 | 06:40 PM
ON-UJAH's Avatar
ON-UJAH
A very nice piece of kit the GReddy - it will work on any Turbo engine.
Set up is very quick and easy - set the 'set gain' to about .2bar under what you want to run, then use the 'set' to get your required boost level - use the higher gears to find this.
Finally play with the gain to reduce boost spike to an acceptable minimum - in the lower gears a spike of .1 - .2 bar should be OK.
Thats all - it has 2 levels so set up the lower one for daily driving, and the higher one for when you need an extra kick.
Run the solenoid as near to the turbo as possible but away from any heat.
Highly recommended - these can handle up to about 2 bars of boost without problem.
BTW GReddy is pronounced similar to 'ready' (but how Tony the Tiger might say it) , not like 'greedy'.
Old Dec 17, 2006 | 07:07 PM
Tony Turbo's Avatar
Tony Turbo
Great info there. I wish I knew that 2 years ago
That's why I'm off- loading mine to some mug, er I mean Andy
Old Dec 17, 2006 | 10:31 PM
AndyRST's Avatar
AndyRST
imagine my Focus flashing you out the way at 150mph while i run 2bar, muhahahaha who be the mug then?
Old Dec 18, 2006 | 12:23 PM
NathR's Avatar
NathR
You, when your turbo goes pop after a few seconds!!
Old Dec 18, 2006 | 02:59 PM
AndyRST's Avatar
AndyRST
GT28 anyone ?
Old Dec 19, 2006 | 11:55 AM
Tony Turbo's Avatar
Tony Turbo
Not with a Greddy Boost controller you won't
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
