Oil ???????????????????????????????????????
Old Dec 11, 2006 | 10:28 PM
T4 Phil's Avatar
T4 Phil
Default Oil ???????????????????????????????????????
Does any 1 no what oil 2 recemend 4 my saph its had new lifters and tappets but theres always 1 lifter rattling????????? on start up......
Old Dec 12, 2006 | 04:34 PM
bigad4x4's Avatar
bigad4x4
I used to use Castrol Rs 10-60 but was told it didnt protect the engine
when very hot so changed to Siloklene Pro-s 10-50 and seems fine at the
moment but my engine has only covered 2000 miles on a rebuilt engine
would go for a very similar grade and you will be just fine
Old Dec 12, 2006 | 05:02 PM
kevin cozzer's Avatar
kevin cozzer
Default oil
Mate mobil 1- 15/50w is THE only oil for cossies, mobil 1 used cossies in the testing of it.
llw's Avatar
llw
Castrol Rs 10-60 - i was using that but it made my engine very loud
think i'll be changing to mobil 1 15-50 now, is that ok?
Old Dec 13, 2006 | 06:16 PM
DAN P's Avatar
DAN P
15 50 moble 1 m8
Old Dec 13, 2006 | 07:22 PM
rapidcossie's Avatar
rapidcossie
i run 10 60 castrol and my engine is very quiet..have done for 10k miles
does anyone on this thread understand what the numbers mean?
if your engine is noisy on start up a thinner oil (when cold) 10w will be better.
As for the castrol not protecting the engine when hot again a thicker oil when hot ie a 60 rather than a 50 will be thicker and less likely to break down so will protect better at higher temps
Old Dec 14, 2006 | 01:53 AM
cossieboyIOW's Avatar
cossieboyIOW
is 5/50 no good?
Old Dec 14, 2006 | 05:23 PM
rapidcossie
its probably fine as with cossies i believe its the second number that most important
Old Dec 16, 2006 | 01:04 PM
DAN P's Avatar
DAN P
i no moble one will run at 115 degres
Old Dec 17, 2006 | 10:28 AM
CosKev3's Avatar
CosKev3
As above,Mobil 1 Motorsport or Silkolene are whats recommended by Oilman off here
Deffo says not to use Castrol RS 10 60
Do a search on here for posts by Oilman,hes done a write up explaining all the numbers on oils
Which ever you decide on,buy it from him,great service to your door
Old Dec 17, 2006 | 03:32 PM
PSL's Avatar
PSL
I had similar noises on start up and changed my oil to Silkolene Pro S 10w-50.
A bit pricier, but no noise at all now.
Old Dec 17, 2006 | 03:36 PM
rapidcossie
i have spoken to oilman a few times about oils..
he says that the silkolene is the best quality oil and thats what he recommends...
He told me that Castrol is a good oil and suitable for my car but the silkoene is better.
Old Dec 19, 2006 | 09:42 PM
richm's Avatar
richm
most sensible post on this thread
you will get good advice from oilman
Old Dec 19, 2006 | 09:46 PM
rapidcossie
Me? sensible....nah
Old Dec 21, 2006 | 12:47 PM
dan5710's Avatar
dan5710
I AGREE, MOBIL 1 15W/50, WOULDNT RUN IT ON ANYTHING ELSE.
Old Dec 21, 2006 | 02:15 PM
richm's Avatar
richm
then you may well be missing out on a better option.. check out Silkolene Pro-S and Pro-R
Old Dec 21, 2006 | 02:22 PM
Csm's Avatar
Csm
Silkoline aint that special and is known to make ur tappets rattle there tits off !!!
Im speaking from experiance here
i used castrol rs for years and no problems with it
also used others with no probs
i think some peeps just enjoy silkoline cos its different colour and looks like blackcurrant juice thats going in and thats cool
oils are good in diff ways and some are better in engines depending on its condition in first place
Old Dec 21, 2006 | 02:43 PM
richm's Avatar
richm
Silkolene IS special as oil goes...
as to whether your tappets rattle their tits off is due to a number of issues.
Mine don't for example, on a 100k mile engine, but then tappets are new
The more important bit is that it maintains oil pressure under hard use when it's hot, without starting off like syrup to be able to achieve that
Old Dec 22, 2006 | 11:38 AM
CosKev3's Avatar
CosKev3
Wotever!!!!!!
As above,your tappets prob need replacing
Think Oilman/Opie oils have a bit more knowledge than you on what oils are good and not good
Old Dec 23, 2006 | 02:00 PM
dakar's Avatar
dakar
Hi there lads,i am new to this passion ford stuff.You are on about oils and lifters etc and say they still rattle after replacement,does anyone know if its important to buy genuine lifters or cheapos cos mine rattle like mad but cheapos r half the price of genuine ones.cheers
Old Dec 23, 2006 | 08:02 PM
philbert's Avatar
philbert
Default oil
Mobil 1 15w/50w is the ONLY oil to use. Granted it costs a lot but U get what U pay for, Its also used in high reving F1 cars which rev to 20.000 rpm so its up to the job of high performance
Old Dec 23, 2006 | 08:13 PM
rapidcossie
the stuff you buy from halfords is NOT the same oil used in F1 cars
some people believe anything
Old Dec 23, 2006 | 08:15 PM
richm's Avatar
richm
Mobil1 is far from the ONLY one... if it's the one you like, then that's fine it will perform well, but there are "better" oils out there for the same price.
Take advice from Oilman/Opie Oils, they will be happy to sell you whatever you want, including Mobil and Castrol, but they will also offer first class professional advice for your particular application and usage style and recommend the best oil available in each case - but ultimately they will be happy to sell you anything you wish
Old Dec 23, 2006 | 09:47 PM
snow*'s Avatar
snow*
I wouldn't ever use Mobil 1 (note the correct spelling)
I'd got one step better and use Silkolene Pro R or Pro S or what I currently run Motul 300V Competetion 15w 50
Old Dec 25, 2006 | 10:36 PM
CosKev3's Avatar
CosKev3
https://passionford.com/forum/viewtopic.php?t=158586
Old Dec 26, 2006 | 09:07 AM
Merry Christmas from Burshgh
http://christmas-orgasms.info/
Old Dec 27, 2006 | 08:40 PM
rabmc's Avatar
rabmc
Motul 300v 15-50 race oil
Old Dec 27, 2006 | 08:58 PM
jim393cos's Avatar
jim393cos
Default oil
I use mobil 1 motorsport 15/50 its done a good job in my cossie and my rs turbo. on the subject of cam follower rattle if using correct grade of oil its going to be the followers.I have built a few cossie engines the ones that had new aftermarket followers in started to make noise on start up again after abut a year.I was lucky enough to find a new set of kent cams ones on ebay cheap these are still quite even after months in the garage untouched
Old Dec 28, 2006 | 09:53 PM
Jo's Avatar
Jo
I always used (and still use) Castrol RS 10w60 in my cossies. Never had a problem, so it can't be that bad some people say.
Old Dec 29, 2006 | 07:52 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Mobil 1 15/50 It's what I use and it has worked very well in both my Cossie and my brother's RST.
Cheap if you know where to get it from too
I'm sure Silkolene is good stuff, but I like the cheaper price of an oil that does the job fine. Hence Mobil 1.
Si
Old Dec 30, 2006 | 04:00 PM
rob741's Avatar
rob741
silkolene pro s recomended
Old Dec 30, 2006 | 04:49 PM
Tarren's Avatar
Tarren
15-50 mobil 1
Matt lewis does it Ł20 at the shows mate
Old Dec 30, 2006 | 06:39 PM
costina's Avatar
costina
Live long and prosper!!
Si
yeah you know it Si
Mobil 1 motorsport
Old Dec 30, 2006 | 07:44 PM
rinus_2005's Avatar
rinus_2005
how about valvoline 10w60?
i had a heat issue with castrol 10w60, and a cosworth tuner informed me that he uses Valvoline instead because that withstands temperatures up to 144 degrees celcius before burning up(changes within the oil and loosing lubrication properties) and castrol @116 degrees celcius.
(car is used on tracks only, even on hot summer days)
Old Dec 31, 2006 | 11:48 AM
mumbo jumbo's Avatar
mumbo jumbo
i use 15w 40 magnetec i have no probs with it and only top up every 4 weeks as she dont burn oil even under booting it around done 200k since rebuild
Old Dec 31, 2006 | 03:55 PM
stonehavencossie's Avatar
stonehavencossie
I use silkolene as recommended by oilman and stu (msd) never had any problems
Those of you saying you cant use anything other than mobil 1 ......errr shut it !!
Old Dec 31, 2006 | 04:37 PM
melzieann's Avatar
melzieann
i now use Silkolene pro S as was advised by a lot of tuners
Old Jan 1, 2007 | 02:50 PM
costina's Avatar
costina
I used this stuff a long time ago engine rattled like a box of spanners
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
