fuel pump and vibrating
Old Dec 11, 2006 | 08:05 PM
kevin cozzer's Avatar
kevin cozzer
Default fuel pump and vibrating
Does anyone know how to wire new wires to my fuel pump using the original wires to power a relay, with a wire straight from the battery? what type of fuse? wattage? wire? my fuel pump is only kicking out 11volts! i don't want the saph to go bang!
would any one know why my saph would just start vibrating between 2500 and 3000 rpm it's been poly bushed but never done it before or since then?
Old Dec 12, 2006 | 12:13 AM
jon@work's Avatar
jon@work
mount a relay in the boot area (I mounted mine where the fuel cut-off switch is)
take the original fuel pump feed wire off the pump to pin 85
run a new wire (doesn't have to be heavy gauge) from pin 86 to an earth point
run a new 30-35A wire, with a 40A fuse near the battery, through the front bulkhead (with a grommet) to pin 30
run a new 30-35A wire from pin 87 to the fuel pump
run a new 30-35A wire from the pump to earth
Old Dec 22, 2006 | 09:39 AM
2wd's Avatar
2wd
Hi...why do you put the feed to pin85 and the earth to 86 ?? I thourght that you normally put ++ to pin 86 and earth to 85 ??
Old Dec 22, 2006 | 09:42 AM
jon@work's Avatar
jon@work
can be either - that's just the way I normally wire up relays
Old Dec 22, 2006 | 09:48 AM
2wd's Avatar
2wd
ok..thanks ..
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
talon1
Sep 15, 2015 10:27 AM
tib2220
Sep 14, 2015 12:33 PM
