Which Cam Belt
i just go with the ford item so 1 you know your getting the correct one
and 2 thats what they had when ther new i would only think about getting a uprated one if my car was running high revs
You can also use a good aftermarket one like Contibelt. At least as good as genuine Ford but usually a bit cheaper.
More important than the manufacturer of the belt is, that you also change the tensioner and the water pump.
Mc5506
Oct 5, 2015 09:57 PM
