RST hot start problem
Old Dec 5, 2006 | 09:39 PM
Dragsteer's Avatar
Dragsteer
Default RST hot start problem
Hello everybody
I have RST for about one month. Car starts ok when is cold, but when I driving around and turn engine off, and for about 30 min try start it again, it wont.
Any ideas? thanks
sorry about bad english
Old Dec 5, 2006 | 10:36 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Starter motor, VERY common problem.
Get one from a smaller cvh engine and heat wrap the downpipe.
Old Dec 5, 2006 | 10:50 PM
Zetecfiesta's Avatar
Zetecfiesta
what he said! luckly i havent had this problem yet!!
Old Dec 5, 2006 | 10:55 PM
L3 COS's Avatar
L3 COS
ive had that problem with just about everyone ive had, but have now cured it once and for all, buy a lucas one, part number LRS 788.
they are the bollocks!! they work completely different to the standard cvh starter,they are geared and sound like a cozzy starting you wont get no hot start problems with one of these trust me,they are more expensive mind but will out last half a dozen of the other type.
make sure you go to a LUCAS supplier,dont let them blag you into a different make telling you its the same,it must be a lucas LRS788 in a green box!
hope this helps alot of you with rst,s
Old Dec 6, 2006 | 01:35 AM
NUTS RuS's Avatar
NUTS RuS
Can also be the sign of a lazy battery low on cranking amps
Old Dec 7, 2006 | 12:50 PM
Dragsteer's Avatar
Dragsteer
thanks you for advices. i will change startet motor hope this will help
Old Dec 7, 2006 | 03:56 PM
MattyRST's Avatar
MattyRST
L3 cos does that lucas starter bolt straight on like the cvh starter, or would i have to adapt it to fit ??
Old Dec 7, 2006 | 05:13 PM
Dragsteer's Avatar
Dragsteer
sorry , but my starter is turning when I turb key , but car wont start. after drive, I turn off car go eat and back after 30 min. and try to turn it on. engine strts but suddenly turn off. and I try again and starter is turning and turning....and after 20 sec he starts but engine works like on 3 cilinders, and after I ush trotlle engine starts workingg normaly.
maybe injecotr leak??
Old Dec 7, 2006 | 05:29 PM
NUTS RuS's Avatar
NUTS RuS
Maybe low fuel pressure ? Are the spark plugs ok ?
Old Dec 7, 2006 | 08:59 PM
Dragsteer's Avatar
Dragsteer
i have fuel pump 3.5 bar serial is 5.5 bar. maybe because of shitty pump?
but some people said that pump is ok some people said that pump is too weak.
Old Dec 7, 2006 | 09:25 PM
NUTS RuS's Avatar
NUTS RuS
can you turn it down (reduce pressure ?)
Old Dec 7, 2006 | 10:17 PM
L3 COS's Avatar
L3 COS
it bolts straight on no messing mate,the only thing you might have to do is change the spade connector for a bullet connector and thats it!! trust me once you get one of these you wont go back to the old type
Old Dec 8, 2006 | 04:58 PM
Dragsteer's Avatar
Dragsteer
how reduce pressure? i dont understand. my fuel pump is from bmw. 3.5 bar i think. but i think maybe injector leak?
Old Dec 8, 2006 | 05:44 PM
NUTS RuS's Avatar
NUTS RuS
with an adjustable regulator
3.5 bar sounds a lot of pressure ?? It may be forcing fuel out through a leaky injector and filling the cylinder ??
Old Dec 8, 2006 | 05:48 PM
MattyRST's Avatar
MattyRST
Thanks L3 COS ill get one asap !!!
Old Dec 8, 2006 | 05:53 PM
L3 COS's Avatar
L3 COS
superb!!! let me know how you get on and wot you think mate??
Old Dec 8, 2006 | 06:02 PM
MattyRST's Avatar
MattyRST
Will do L3 COS cheers again
Old Dec 9, 2006 | 02:28 PM
Dragsteer's Avatar
Dragsteer
no , original fuel pump is 5.5 bar , but now i have only 3.5 bar.
fuel pump has 5.5 bar till fuel pressure regulator, then is going about 3.X.
Old Dec 9, 2006 | 03:08 PM
XR2's Avatar
XR2
On top of the fuel pump sits a valve that holds the pressure in the fuel lines after turning the engine off.
When the fuel in the lines get warmer, they get gas bubbles and they will push petrol back into the tank. So you'll have to wait until the fuel gets colder and the gas bubbles disappear until you can start the engine again. So fit a new valve to your fuel pump!
Old Dec 10, 2006 | 11:29 AM
Dragsteer's Avatar
Dragsteer
ok. but i have bmw pump, and that pump maybe dont have this valve?
can i solve problem and fit new pump?
Is possible that one of injector leak?
Old Dec 10, 2006 | 03:39 PM
Alex_86's Avatar
Alex_86
i would get a pump for a ford (cvh or cossi) but yes your injectors could leak
Old Dec 10, 2006 | 05:29 PM
XR2's Avatar
XR2
If you smell petrol out of your exhaust then you'll have too much of it in your engine.
If not, it will not get any petrol. And in most cases it's the valve!
Old Dec 11, 2006 | 11:47 AM
Dragsteer's Avatar
Dragsteer
yes smell of petrol is strong, when I try to start engine.
edit: I find in autodata that problem is starting can be in DIFFERENTIAL PRESSURE (wtas it that?? ), cold start injector, warm up enrichment function. ?
Billy_RS
16
Oct 11, 2025 09:41 PM
A.t.p
Aug 15, 2015 11:37 AM
Sjieter
Aug 5, 2015 09:47 PM
dlwarrior
Aug 5, 2015 10:19 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
