RST hot start problem
Hello everybody
I have RST for about one month. Car starts ok when is cold, but when I driving around and turn engine off, and for about 30 min try start it again, it wont.
Any ideas? thanks
sorry about bad english
Any ideas? thanks
ive had that problem with just about everyone ive had, but have now cured it once and for all, buy a lucas one, part number LRS 788.
they are the bollocks!! they work completely different to the standard cvh starter,they are geared and sound like a cozzy starting you wont get no hot start problems with one of these trust me,they are more expensive mind but will out last half a dozen of the other type.
make sure you go to a LUCAS supplier,dont let them blag you into a different make telling you its the same,it must be a lucas LRS788 in a green box!
hope this helps alot of you with rst,s
sorry , but my starter is turning when I turb key , but car wont start. after drive, I turn off car go eat and back after 30 min. and try to turn it on. engine strts but suddenly turn off. and I try again and starter is turning and turning....and after 20 sec he starts but engine works like on 3 cilinders, and after I ush trotlle engine starts workingg normaly.
maybe injecotr leak??
i have fuel pump 3.5 bar serial is 5.5 bar. maybe because of shitty pump?
but some people said that pump is ok some people said that pump is too weak.
Originally Posted by MattyRST
L3 cos does that lucas starter bolt straight on like the cvh starter, or would i have to adapt it to fit ??
no , original fuel pump is 5.5 bar , but now i have only 3.5 bar.
fuel pump has 5.5 bar till fuel pressure regulator, then is going about 3.X.
On top of the fuel pump sits a valve that holds the pressure in the fuel lines after turning the engine off.
When the fuel in the lines get warmer, they get gas bubbles and they will push petrol back into the tank. So you'll have to wait until the fuel gets colder and the gas bubbles disappear until you can start the engine again. So fit a new valve to your fuel pump!
ok. but i have bmw pump, and that pump maybe dont have this valve?
can i solve problem and fit new pump?
Is possible that one of injector leak?
If you smell petrol out of your exhaust then you'll have too much of it in your engine.
If not, it will not get any petrol. And in most cases it's the valve!
yes smell of petrol is strong, when I try to start engine.
edit: I find in autodata that problem is starting can be in DIFFERENTIAL PRESSURE (wtas it that?? ), cold start injector, warm up enrichment function. ?
