top end rebuild
whats needed for a top end rebuild? my turbo is starting to get a bit rattly on top, i know its had a bottem end rebuild so thats good, but what parts do i need for a top end rebuild? or should i just buy a top end thats allready been done? also which cam kit is the best to go for? my car is only mildly tuned and i dont want it to get too laggy, got a grs fron mounted intercooler, k&n, exhaust, bleed valve and its allready chipped but will probably rechip when i get the new head.
i would say get:
CVH34 or a standard ford cam kit
Hydraulic lifters
rockers
rocker bolts
top end gasket kit (Payne)
Re-seat valves
genuine ford head gasket
de-coke the head
and that would be perfect
oh and maybe a re-skim on the head if it needs it
its what i have done on mine and its sweet
bassboy
Hydraulic lifters
rockers
rocker bolts
Re-seat valves
de-coke the head
bassboy
Originally Posted by UnseenMenace
I would get rid of that bleed valve unless your looking for problems
from experience the prob is not the bleed valve but the person that tampers with it,if you sort that prob then the bleed valve will give you none
Originally Posted by addiction
agreed, there is nothing wrong with bleed valves what so ever! a lot of tuner's use them and as said above it's the people that play with them that get problems!!
This is a cheap and fast way to increasing performance and a faster way towards engine problems, it has been proven time and time again.. To say that the problem of bleed valves is related only to people who play with them is incorrect, they ignore many of the basic requirements of the engine and remove protection... and you believe this is OK or that nothing is wrong with it.
I would never ever use a tuner who thought that removing boost limits or fitting a device which allows an engine to detonate though its basic design flaws was acceptable
the ecu takes it reading from the inlet manifold
a bleed valve is just a mechanical amal valve
Thats bit of an excessive list to quieten a top end IMO.
A new and cam lifters, and possibly rockers depending on whether they are worn.
An oil change and filter also, and it should be nice and quiet!
And i also agree bleed valves are fine as long as they aren't abused, And alos you should only ever fit a re-circulating bleed valve onto an MFI car, see far too many with bleed valves that waste to atmosphere
ive never messed with my bleed valve and the car has been fine! tbh i will probably get a full top end rebuild as the bottom end has been done and it will all be good with the top end done!
thanks for the info bassboy!
now wheres that christmas wish list! lol
Having valves re-lapped in etc won't really benefit you if you aren't losing compression from there, and being perfectly honest, if your going down that route it wouldnt be a proper job without new valves and valve guides either, which all soon adds up and contributes to the bill, especially seeing as the valve guides need to be pressed in.
If all your looking to do is get it quieten it down then just do what i have suggested above and also save some money!
Wilsfoci
15
Mar 30, 2016 10:26 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
