This is a new one!! Help needed!!
Old Dec 3, 2006 | 07:36 AM
m_nettleship's Avatar
m_nettleship
Default This is a new one!! Help needed!!
I have a 2wd sapphire cos, and I have just started to hear what sounds like water running behind the dash, on the drivers side in the right corner. it does it most when it revs, checked no water leaks or owt like that. its quite loud. and the other prob is I put 3door clocks in with the boost gauge, speedo worked fine the just stoped, cable seems fine at the bk. Any help well appreciated lads.
Old Dec 4, 2006 | 07:44 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
could be the heater matrix
Old Dec 4, 2006 | 09:17 PM
m_nettleship
what leaking or nackered.
Old Dec 4, 2006 | 09:29 PM
Matt Baxter
Back in black!
poss both
but if it was leaking the carpet would be wet and youe eye might be stinging because of the anti freeze leaking
Old Dec 6, 2006 | 01:21 PM
m_nettleship
its as though its right in the corner to ur right. well found a new prob today, posted it though.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
