TPS
Old Nov 30, 2006 | 11:52 AM
davidnormanuk's Avatar
davidnormanuk
Default TPS
How can I check to make sure its working as it should be? It does click when opening the throttle slightly but think this is the cause of my holding back.
Dave
Old Nov 30, 2006 | 03:49 PM
SafeChav's Avatar
SafeChav
Presumably on an MFI RS?
TURBO BOI's Avatar
TURBO BOI
resistance check on the pins using a multimeter, haynes manual has got the the correct tolorence in it
Old Nov 30, 2006 | 03:51 PM
SafeChav's Avatar
SafeChav
Thats only for EFI
Whoa boy
Old Nov 30, 2006 | 03:56 PM
TURBO BOI's Avatar
TURBO BOI
isnt the tps on mfi electric?
davidnormanuk
Sorry yes it's MFi at the minute. I don't want to take the car off the road as yet as it's a bit cold for the bike.
Dave
Old Nov 30, 2006 | 03:59 PM
SafeChav's Avatar
SafeChav
The MFI TPS is 2 switches basically.
One to tell the ECU idle (closed throttle) and one to tell it full throttle.
Leave it on the car, and you should have continuity between the centre pin, and one of the outer ones.
Then, hold it at full throttle, and you should see continuity between the centre pin and the OTHER outer pin in the plug.
Check for eratic readings and so on, i had one that had broken its solder joints inside and was very intermittent!
Old Nov 30, 2006 | 05:43 PM
Rick's Avatar
Rick
wont be the cause of the problem, it doens't do an aweful lot. Infact i dont run one....
Old Nov 30, 2006 | 07:17 PM
SafeChav's Avatar
SafeChav
Rick......
You don't call the SOLE trigger of full load enrichment important........
Old Nov 30, 2006 | 08:14 PM
Rick's Avatar
Rick
Depends. It won't richen it up enought to help with hesitation.
I set mine so it is rich enought at part throttle too.
Old Nov 30, 2006 | 08:25 PM
SafeChav's Avatar
SafeChav
I had a problem with intermittent hesitation at full load and turns out mine was knackered.
Cured the problem for me!
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
