Is It Common For Rad Fans To Be ON When RS500 Cooler Fitted?
Old Nov 30, 2006 | 09:35 AM
J9BBY's Avatar
J9BBY
Default Is It Common For Rad Fans To Be ON When RS500 Cooler Fitted?
Got a stage three sapphire with RS500 style intercooler. Is it common for the radiator fans to be on a LOT with the standard radiator? I've changed the thermostat, fan switch, and flushed the sysem with no difference. The temp gauge never goes above the O, generally sits between the R and the O.
If this is common, what remedy is usually used??
Cheers,
Pete.
Old Nov 30, 2006 | 11:40 AM
TurboShed's Avatar
TurboShed
Cossiemodo
How much is "a lot"??
Old Nov 30, 2006 | 01:33 PM
J9BBY's Avatar
J9BBY
I'd say over 50% of the time. And it is always both of them that are on. There is never just one on at a time. As it is a two stage fan switch i trhought this stange.
Pete.
Old Nov 30, 2006 | 02:16 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Yes they are on a lot and stay on for a long time. The escorts have a 2 stage fan switch, but i dont think Saff's do. Ive only ever known both fans to be on and that on mine, my mates 3 door and another mate who used to have a saff, so unless all of ours are fucked then dont worry
Old Nov 30, 2006 | 08:15 PM
J9BBY's Avatar
J9BBY
Terrific That's just what I wanted to hear!!! That puts my mind at ease.
Would a water wetter make any difference or are they crap?
Cheers for that,
Pete.
Old Nov 30, 2006 | 08:24 PM
rapidcossie's Avatar
rapidcossie
nowt to worry about mate..
the cooler blocks the flow to the rad a bit..
Old Dec 2, 2006 | 11:09 AM
RobCarden's Avatar
RobCarden
358bhp
mine are on a fair amount- most times when i stop the fans will be on...
car doesn't get to hot. stays around 80 - 85 deg on a hot day in traffic, very very rarely it goes to 90.
Old Dec 2, 2006 | 11:53 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
i got alloy rad aswell as a rs500 cooler,fans on bout same times as with std set up
markk
Dec 2, 2021 06:59 PM
Dicko&Vacant
Aug 21, 2015 05:59 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
TIL13R
11
Aug 13, 2015 02:28 PM
track.focus'd
Aug 12, 2015 05:53 PM
