1.8 ZVH, info needed,
Old Nov 27, 2006 | 09:51 PM
Fiecos Dan's Avatar
Fiecos Dan
Default 1.8 ZVH, info needed,
Hi,
what compression ratio will a std 1.8 Zetec bottom, with a RST ford H/G, and a std RST head be running,
also what power can std rods, and rod bolts be able to run safely?
Cheers Danny
Old Nov 28, 2006 | 05:47 PM
ivorbiggun's Avatar
ivorbiggun
Here you go mate work it out for yourself,- www.turbofast.com.au/Tfcomp.html
Old Dec 21, 2006 | 04:36 PM
Fiecos Dan's Avatar
Fiecos Dan
Cheers mate,
but i know how to work it out,
but i need the
bore size,
Stroke,
Head and H/G capacity??
Old Dec 21, 2006 | 05:31 PM
Johnny Knoxville's Avatar
Johnny Knoxville
If you bolt the standard head down to the 1.8 zetec bottom end you will get 8.5:1
Old Dec 21, 2006 | 09:54 PM
Fiecos Dan's Avatar
Fiecos Dan
Cheers Jonny,
is that using a Ford RST H/G?
Which head bolts are used?
Old Dec 25, 2006 | 09:31 AM
Fiecos Dan's Avatar
Fiecos Dan
any info welcome.
Old Dec 25, 2006 | 10:34 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Why not just go zetec?
Old Dec 25, 2006 | 01:39 PM
Fiecos Dan's Avatar
Fiecos Dan
its not for me,
and he's budget is real tight, so its either a a std rst rebuild, or a zvh.
its all on a xr2tt, so the powers limited to what parts he alread has on his car.
Old Dec 25, 2006 | 01:56 PM
Wardy257's Avatar
Wardy257
A standard ZETEC will make as much power as a standard RST. No turbo lag, better fuel economy, better response etc.
Old Dec 25, 2006 | 02:05 PM
Fiecos Dan's Avatar
Fiecos Dan
i know what Zetec's can do,
But he's car is a turbo car, and thats the way he wants it. and its not std
I said a std rst engine, not power.
Old Dec 27, 2006 | 09:42 AM
Johnny Knoxville
Originally Posted by Fiecos Dan
Cheers Jonny,
Ford head gasket and bolts
Old Dec 27, 2006 | 10:06 AM
Fiecos Dan's Avatar
Fiecos Dan
What head bolts tho,
as std cvh ones are too short.
Old Dec 27, 2006 | 01:28 PM
tim10_10's Avatar
tim10_10
You either need to mill the head bolt platforms down to get the correct thread engagement which obviously then leaves the head only suitable for zvh's or I have used a head bolt set from a 6 clyinder bmw engine witha female torque head. Unfortunately I cant remember what car it was exactly but you could look up and compare in head bolt book perhaps.
Old Dec 28, 2006 | 09:07 AM
Fiecos Dan's Avatar
Fiecos Dan
Cheers mate,
i'll try and get longer bolts from a bmw.
Old Dec 28, 2006 | 10:15 AM
rs220bhp's Avatar
rs220bhp
Found these mate dont know if there any good, Also they meed to be around 150mm long and 12.9 spec if that means anything to you.
http://cgi.ebay.co.uk/1-8-2-1-ZVH-RS...QQcmdZViewItem
Hope this helps
Steve
Old Dec 28, 2006 | 10:32 AM
Fiecos Dan's Avatar
Fiecos Dan
Thats perfect, Cheers mate.
Del gsxr
Feb 11, 2016 05:37 AM
Porplus12
Sep 10, 2015 07:20 PM
cos elle
Sep 1, 2015 06:48 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
col93saphcos
Aug 7, 2015 03:21 PM
