Quick button wiring question
Old Nov 27, 2006 | 08:27 PM
Rippers's Avatar
Rippers
Monte Geek
Default Quick button wiring question
Right hand side of the steering wheel two button Front fogs and front heated screen. One has a grey plug the other has a blue plug.. which way around do they go
Its not cold enough in the garage to see the heated screen work and I have no front fogs
Old Nov 27, 2006 | 08:29 PM
Damo V's Avatar
Damo V
Shoould only go on one way mate
Old Nov 27, 2006 | 08:32 PM
Rippers's Avatar
Rippers
Monte Geek
Thats what I would have thought but they are exactly the same plugs just different colours
Old Nov 27, 2006 | 08:57 PM
Damo V's Avatar
Damo V
Ive taken mine apart loads of times never gone back wrong, never stopped to think abut it just plugged them on ... are you sure one of them doesnt have a "loose" wire for the illumination whereas the other uses the multiplug loom???
Old Nov 27, 2006 | 09:15 PM
Rippers's Avatar
Rippers
Monte Geek
They both have a loose wire for illumination
Old Nov 27, 2006 | 09:20 PM
Damo V's Avatar
Damo V
oh.... dunno how I managed to get them right then.... Thee must be a way to tell???
same style multiplugs but are the male/female spade terminals in the same place in relation to each other??
Old Nov 27, 2006 | 09:21 PM
Rippers's Avatar
Rippers
Monte Geek
Think its going to be pic time
Old Nov 28, 2006 | 07:21 AM
Franco's Avatar
Franco
Just press/hook them both up mate, i could never work out which was for the front & the back either!.............
So me being a good boy scout, just pressed both when in doubt!!
Old Nov 28, 2006 | 09:26 AM
Rippers's Avatar
Rippers
Monte Geek
Well tbh with no front fogs It doesn't matter so your theory sounds good mate
Old Nov 28, 2006 | 01:46 PM
PewteRS's Avatar
PewteRS
If you got any front fogs there just plug 1 in for testing.
Old Dec 1, 2006 | 03:47 PM
Dave Henshall's Avatar
Dave Henshall
they are the same plug with a differnt key, there is a T shape that is a different way round in the moulding if you look closely - you probably can force them on either way, but one way will be obvious
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Bransby
Sep 11, 2015 01:09 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
fuzzy
Sep 4, 2015 10:11 PM
