expert needed vauxhall vectra not starting
Old Nov 26, 2006 | 07:59 PM
abdr500's Avatar
abdr500
Default expert needed vauxhall vectra not starting
hi I have a vauxhall 1.8 x reg vectra that I am trying to get started it won't start but will turn over both management lights are on and 1 will flash was told its a immobilizer problem tried putting the snap on diagnostic reader on there but comes back with fault not recognized is there a way of programming the key could that have lost its program or what ells could it be any help appreciated thanks
Old Nov 26, 2006 | 08:53 PM
abdr500's Avatar
abdr500
were are you chip 3 door
Old Nov 26, 2006 | 09:03 PM
Iain Mac's Avatar
Iain Mac
I'm no expert on this, but could the crank and cam sensors have gone out of sync or one of them have dried out? That was the eventual problem on mine, and after the AA guy read the codes he popped the sensors out, gave them a quick squirt of WD40 and the car started first time.
Old Nov 26, 2006 | 09:05 PM
abdr500's Avatar
abdr500
Iain Mac
i will try that tomorow but no codes are coming up on my dignostic test
Old Nov 26, 2006 | 10:20 PM
carfixz's Avatar
carfixz
you aint recently changed the battery in the fob have you? Inside the fob there is a transponder for the immobiliser, they fall out sometimes when the batteries are changed
Old Nov 26, 2006 | 10:25 PM
SPADGE's Avatar
SPADGE
Vectra's are renowned for immobilizer and ecu problems hopefully you will be lucky but don't count on it!
Old Nov 27, 2006 | 01:52 AM
Here but i know FUCK ALL about modern vauxhall immobilisers, my interest in cars tends to end at about 1990
Fordmad!
Sep 26, 2015 05:24 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Bailes1992
Aug 16, 2015 07:14 PM
nick8saff
Aug 16, 2015 05:35 PM
col93saphcos
Aug 7, 2015 03:21 PM
