fuelling advice
Old Nov 26, 2006 | 02:02 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default fuelling advice
put a wideband on the binliner and on boost it is in the 11s but on idle it is around 15-14.5 but gradually gets richer and richer every few seconds or so until after around 3 minutes it will be in the mid to early 12s. This shouldnt happen should it,so what would cause it to richen up on idle like it does? std lambda??
Old Nov 26, 2006 | 02:21 PM
Jay,'s Avatar
Jay,
Sponsor
if its at 14.5/15 at norm temp at idle then gets lower as it gets hotter could be just compensation in the ecu ect but 11 are finr on boost danny
Old Nov 26, 2006 | 02:23 PM
dannyblackpool
Boost Builder
so it dropping into the early 12s on idle is ok and wont be borewashing etc? if i lean it off on the safc it just makes it mega lean on idle the next time i stop until its sat a few mins and richened back up
Old Nov 26, 2006 | 02:25 PM
Jay,'s Avatar
Jay,
Sponsor
have u got a temp compensation table on the ecu dan
Old Nov 26, 2006 | 02:30 PM
dannyblackpool
Boost Builder
its the standard ecu m8 with a air fuel comp which manipulates the afm signal. crude idea but helps cure the overfuelling stage 1 mods cause,so no i havnt, plugged lappy in and ran some sofware which reported no sensor issues etc but other than that,the wideband and egt gauge with knock sensor its all ive got to help get it right. How dangerous is running lean on idle??
Old Nov 26, 2006 | 02:33 PM
Jay,'s Avatar
Jay,
Sponsor
sent u pm
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
