CVH/ZVH rev limits
Originally Posted by sas
I am wondering where you all have set your rev limits?
Also who has pulled a rocker stud out of the head and what revs?
Regards,
Simon.
Regards,
Simon.
i think mine is 6800 pulled a rocker stud at 6600rpm but i think this was due to the newman solid lifter locknut coming loose giving me no clearance.
but saying that my engine peak power at 6000rpm so in any case i am just over reving it with no gain, i need to drop my final drive to either a 3.5 or 3.3 my current 3.82 does'nt suit my engine.
Mine is 7300 but as I run a plain bearing turbo with cutback wheels (laggy)my turbo is delivaring power from 4200 upwards, so I use the revs to stop it dropping out of the power band between up shifts.
Simon.
Simon.
I have my theries(spelling?) but mine easly revs to the 7300 rev limit in the first 4 gears I just have to get another 300 revs to reach it in 5th. I have nos but have not used it yet!
Remember I have a 8.8:1 CR
The newman cam spec is for big revs (new profile coming shortly)
The inlet manifold can cope with high gas speeds
Sound bottom end
That is just a few points.
Simon.
Sound bottom end
Simon.
Originally Posted by Andy_R
Sorry no pics of the new one lads! Im sure there's old pics floating about of the last one though!
Originally Posted by turbotoaster
correct me if im wrong but are these the pics u need of the your zetec T conversion.....
What can I say, YUP thats mine as of a few weeks back.Call the cops my cars been pap'ed
Originally Posted by scotty86d
my rocker came out at 6500 the rev limit on the old ecu. what a chunt it was
Did you check your valve spring clearance?
whats your spec?
i used to have issue's on one of my old kent35 cam, i used to rev to just under 7000, and it broke a few rockers at different stages.
But never done it on my 1st kent 35 cam setup.
But i checked everything, and clearance's were fine.
TPM961
Jan 15, 2018 10:50 AM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
