Orange Esc. cossy build....****(new pics added 06/01/03)****
This is a picture of the pulleys on the front (head not on yet!)
Engine bay nearly done
NOS plumbed in basically ready to go...
spec of the blue one is massive- not in bhp, but in modifications.
1996 lux with everything inc. twin airbags leather, and aircon.
19'' OZ Superleggera silver
Magnex- no cats
T28 hy-brid with GTi-R comp. wheel etc360, cut blades
Chip with boost limiter removed
Blitz air filter cone & breathers
B & m short shift kit
Clear lights front & sides
Red & clear rear lights
H&R/ Gaz coil overs- decked to f*ck
Modified front grill
2 alarms & tracker
Alpine head unit and Pheonix gold install inc. amp, sub etc
Every samco hose available + more in every different colour
Bailey power steering, header, swirl pot and mirror image oil seperator
Bailey dump valve
1/4 mile 13.5sec @ USC 2003 santa-pod
283bhp & 284ftlb torque @ 3350rpm
CHRIS!!!!!!
Magnex- no cats
2 alarms & tracker
Bailey dump valve
CHRIS!!!!!!
nice one mate,
I saw the blue one at a cruise just passed dagenham, I can't remember
exactly where it was, just remember a nasty speed bump as you some in.
I was parked opposite it, looks the bolox in that colour and with the 19inch
super legera's. What is the name of the colour??
Do you want to sell it? As my mate is shopping for one at the moment, and
still can't find one as nice as yours. Theres quite a few about but it is
proving to be a mission to find one the right colour with the lux package.
Dave
Dave
No it's not for sale (unless...hmmmm...Ł22000)!!!!!!
That should put you off.
It's also got HKS plugs & vibratechnic engine mounts.
SPEC FOR THE ORANGE ONE, SO FAR AS THINGS KEEP CHANGING!!!
ARP 500,000 PSI CON ROD BOLTS
BD14 CAMS FROM PIPER
COLLINS REMAPPED CHIP
COMPLETE GASKET SET (FORD)
DIRECT PORT NITROUS +0-200BHP
10mm MAGNECORE LEADS
DOUBLE VALVE SPRINGS
MOTORSPORT BLUE INJECTORS
INLETS AND EXHAUSTS PORT MATCHED
KEVLAR CAMBELT FROM PIPER
P8 ECU
OVER SIZED PISTONS
NEW HYDRAULIC FOLLOWERS from PIPER
NEW OIL STEM SEALS FROM FORDS
NEW VALVE GUIDES FROM WINSPEED
PACE RS500 INTERCOOLER IN BLACK
MODIFIED INLET CHAMBER
PORTED HEAD & SKIMMED
SAMCO COOLANTS
SAMCO COOLANTS ancillaries
SAMCO TURBO HOSES
STEEL LAYERED WRC HEAD GASKET
TOTAL SEAL PISTON RINGS
VERNIER PULLEYS FROM PIPER
GPA COIL
2WD EXHAUST MANIFOLD
AP CLUTCH?
QUAIFFE BOX
FERODO DRILLED DISCS ALL ROUND
FERODO DS 2000 PADS ALL ROUND
GAZ COIL OVERS ALL ROUND
TINTED REAR LIGHTS
TINTED FRONT FOGS
TINTED FRONT INDICATORS
FULL CAGE WITH DOOR BARS & REAR CROSS
FULLY PAINTED UNDER NEATH
2X COBRA EVOLUTION TECHNOLOGY (YES Ł1150 EACH!!)
SPARCO MONSTER 6 POINT 3'' HARNESSES
OIL TEMP GAUGE
OIL PRESSURE GAUGE
TRANSMISSION TEMP. GAUGE
WATER TEMP. GAUGE
FUEL PRESSURE GAUGE
NITROUS GAUGE
DENSO IRIDIUM PLUGS
SPARCO GEAR KNOB
SPARCO STEERING WHEEL
3BAR BOOST GAUGE
LAMBOURGINI ORANGE PAINT
MODIFIED GRILL & BUMPER
SIDE EXIT EXHAUST & MONGOOSE STRAIGHT THROUGH!
PROGRESSIVE NOS CONTROLLER 0-200BHP
CARBON CENTRE DASH PANEL
FRONT STRUTT BRACE IN BLACK
HEADER TANK BLACK ALLY (BAILEY)
OIL SEPERATOR TANK BLACK ALLY (BAILEY)
POWER STEERING TANK BLACK ALLY (BAILEY)
SWIRL POT BLACK ALLY (BAILEY)
TWO BLACK DUMPVALVES
T34 STAGE 3 HYBRID NEW (SCOTT)
TURBO DAMPER BLACK (BAILEY)
P8 ECU
OVER SIZED PISTONS
SAMCO COOLANTS
SAMCO TURBO HOSES
GPA COIL
AP CLUTCH?
QUAIFFE BOX
TINTED REAR LIGHTS
TINTED FRONT FOGS
OIL TEMP GAUGE
OIL PRESSURE GAUGE
WATER TEMP. GAUGE
FUEL PRESSURE GAUGE
NITROUS GAUGE
DENSO IRIDIUM PLUGS
SPARCO GEAR KNOB
3BAR BOOST GAUGE
NO!!!
wish list includes;
18'' Yokohama A-308 semi slick 225/40 or 225/35 AVS sport
Speedline Torini in white 18'' or
Super T O.Z. (evo new) in white 18'' or
Chrono Evo O.Z. in white 18''
Bigger brakes!!!
wish list includes;
Bigger brakes!!!
Yes it is !!! The underside of the inlet manifold level with the injectors is where the fun begins!
Does yours run OK on NOS?
I found it very tempremental on a 1.9 cvh wiv twin 45's it pi**ed me off alot!
Rik.
The head is done and ready to nail on and if you mean my mate ASH the 'biker guy' yes he always does my engines!!
Craig is gonna do my brake lines ,power steering lines (just got Samco ones!!!)
Kev can help me fitting the car back up as it is in bits.
I am gonna do the rest!
All I need is some light and decent weather.
I'll get some more pictures tonight and load them up tomorrow.
I am gonna be doing the gauges tonight so I'll show you them pics.
Also I just got my orange samco powersteering pipes delivered so I'll put them on as well.
As for haling too much money
I wish ....if I did I would have had it finished 6 months ago!!
pictures underneath this is the REAR COILOVERS, the blue bit is the fuel tank. New callipers, braided lines & Ferodo's.
this is the front end!
Inside is a bit of a mess but I have my new seats to go in yet.
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
slammedorion
15
Nov 1, 2015 07:17 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
