Tips for removing snapped turbo bolts??
Have welded a nut TWICE to one, and it snapped off both times. The other one is flush with the flange and I've spent hours and only half drilled it out!
Turbo to manifold btw.
I laugh\cry cos I know your frustration
drill n tap
hope you get it sorted dude if I can help let me know
Very common on the FRS..... drill it out and use a nut and bolt... it isn't a 2 minute job either drilling them out
If its taken you over an hour you are using shit drill bits, start with summit like a 5mm bit and regularly sharpen it then work up the drill size once you are thru until you can get the right size bolt thru, I'd expect 15 min max tbh on each bolt
Originally Posted by Kev.H
For Sale: Focus RS, Non Runner, Lady Owner, buyer collects any sensible offer
Wats that gotta do with it mate
ps this is not a for sale add
Had the same thing on mine Nath... Took about an hour on each bolt
Drilled em out, but had to borrow some decent drill bits off a friend as i fucked mine up good and proper in a matter of minutes
Good luck with it
Good luck with it
Yeah i did the same thin on me Escort just trying to nip em up
snapped one and continued to nip up another 3
Got em drilled out as they were right in the hole so to speak, or u could get em spark erroded if u can find someone
Good luck
Good luck
@ NathR
You didn't by any chance try to remove these bolts while the engine was still hot did ya? As the bolts expand and proper weld themselves in the thread. I'd know, as I snapped 2 bolts on the flange when I fitted my manifold....oops!
Went through 2 very expensive drill bits to get them out, then went and bought proper, non-ford bolts from a iron works place for £3.50, with proper bolt type tops, not the stupid allen key jobbies!
If you need a set, let me know, much easier to tighten these bolts down, as their the normal kind...
Update, drilled one hole (got some cobalt bits but still took ages) but then whilst tapping snapped the fooking tap holder.
The other one has 10mm of thread sticking out, so I keep welding nuts on, and occasionally snapping them off!!!
Bastard turns 3/4 of a turn both ways but can't get the cunt out, really fucked off tbh.
you can get stud extractors,usually from a good engineer suppliers.
its like a slot drill (milling tool) but what happens is, as you drive the extractor into the end of the stud,it has a left hand flute on the outside which pulls the stud out. you just put them in a power drill.
I broke a tap when trying to re-do mine Nath!
What a twat that was... keep at it mate you`ll get there in the end!!
I spent the best part of 2 days sorting mine out when fitting my manifold!
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
