ST170 ENGINE MODS WHAT BHP TO EXPECT ?
Old Nov 24, 2006 | 05:25 PM
7xrskb's Avatar
7xrskb
Default ST170 ENGINE MODS WHAT BHP TO EXPECT ?
Hi all,
I'm thinking about using the ST170 engine in my project rather than a Zetec.
Looking for about 225 bhp
Would I get this using 45 throttle bodies / management and a flowed head with standard cams ditching the vv timing.
Or would I be better off using the Zetec with bv head / cams / 45 throttle bodies / management ???
Pros and cons pls.
Cheers.
Old Nov 24, 2006 | 09:55 PM
Gordon1's Avatar
Gordon1
the st is very good for tuning i think they are better than a zetec my self
Old Nov 25, 2006 | 12:43 AM
neilm's Avatar
neilm
Default Re: ST170 ENGINE MODS WHAT BHP TO EXPECT ?
You've more chance of being struck by lightening...
Dave at Retro Ford has done 4 cars now with ST170 motors, one was standard on throttle bodies and management with the VVT being controlled by the shift light output on the ECU....
Made 170bhp..
The second was his own development car, on motorcylce throttle bodies and management, made 170bhp
The next one was on a similar set up with a vernier pulley on the exhaust cam, made just over 180
The last one had the VVT removed, CAT Cams, Verniers, Bike Bodies, management, made 195bhp
To get the bhp up near 225 you will have to re-work the head, and bear in mind its very nicely done already, a set of cams, verniers and the key seems to be in raising the compression, a decent exhaust manifold and you may have to go to big valves....
But bear in mind when you get to this stage you need to look at things like rod bolts etc to beef up the bottom end a little...
Old Nov 25, 2006 | 06:45 AM
mark_24v_wiring's Avatar
mark_24v_wiring
Look into the supercharger route it will give you what you want without taking the engine apart
http://www.focussport.com/supercharger.htm
Worth a look
Old Nov 25, 2006 | 09:44 AM
Graham S1's Avatar
Graham S1
Worth a look
or nitrous?
thats a nice looking s/charger kit.
Old Nov 25, 2006 | 12:03 PM
Wardy257's Avatar
Wardy257
225 bhp is not difficult from the normal 2.0 ltr ZETEC. Check out Dunnell engines for ideas.
Old Nov 25, 2006 | 12:06 PM
MAD EVO 4's Avatar
MAD EVO 4
anyway the st170 is a zetec engine but badged as a duratec
Old Nov 25, 2006 | 12:26 PM
JonnyBravo's Avatar
JonnyBravo
I know of a 230bhp St engine which from what I remember was still on a standard bottom end.
As mentioned its all in the headwork and I know this particular one will be as it was done by Nick Waples
No point using nitrous as thats not genuine power, you want something thats there everytime you press the pedal
Old Nov 26, 2006 | 04:23 PM
7xrskb's Avatar
7xrskb
Looks like I willl be going the Zetec route then with TB's, management, bv head and cams.
Just wondered how tunable / easy it would be to get more power from the ST170 engine.
Thanks everyone.
The Underdog
29
Sep 7, 2015 09:49 PM
NoLeafClover
Aug 19, 2015 09:50 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
